Home brew alignment theory
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
Ok so I tackled my 1” front lift today
here is the starting “caster” angle on the top of the ball joint. I put caster in parenthesis because this is not necessarily a perfect caster angle measurement but it does give me an idea of the axles spatial orientation underneath the rig. I zeroed the angle finder on the garage floor
here is the changes I made to compensate for the 1” lift. The factory caster alignment was the same on both sides and it was indicated by the yellow mark. I moved the setting to the silver mark.
here is the after measurement of the angle on top of the ball joint. Sorry for the pic, the spring is in the way of getting the camera closer. Within 1/10° I’ll call that good for now.
And here is the truck with 1” front 0” rear lift on 35”s
Power247
Jan 5, 2020
Looks good! Is there any noticable axle shift with the one inch lift?
Greg
whitexc
Jan 26, 2021
WNY
Greg
This is exactly what I was wondering?
Also, if it's in another thread my apologies but what did you use to get 1"? How involved?
Rockcrawlindude
Jan 1, 2021
Georgia USA
Greg
I can’t see it with my naked eye, but by my trig calculations it should be 1/4”. I think my eye is pretty calibrated so maybe it’s even less than 1/4”
I bought the traxada 1” spacer
how involved? I removed the swaybar links and the shock bottom bolts and the brake line bracket, dropped the axle down and the coil springs fell out.
Rockcrawlindude
Jan 1, 2021
Georgia USA
Seems like the best place to share this stuff
I made a jig for my car so I can make quick toe adjustments with repeatable results at home
I stumbled across this little “tool” and I will probably buy it to use on my solid axle rigs.
jetrinka
Jun 11, 2021
The front ends on these trucks are so freaking frustrating. I swear on my life the steering wheel position changes day to day driving the EXACT same roads in the EXACT same conditions. Sometimes I swear the steering centerline is off to the right a bit and then the next day I swear its off to the left. Verified SO MANY TIMES nothing is moving in the drag link assembly. Ugh I hate it!!! Wrong truck for OCD.....
The beauty of solid axle and large tires lol
Rockcrawlindude
Jan 1, 2021
Georgia USA
It’s a cleaver, not a scalpel.
jetrinka
Jun 11, 2021
Dude I am starting to believe its certainly not a scalpel and likely not even a cleaver. Its more of a square edged shovel with no handle attempting brain surgery....
Whats funny is I came from an 01 Cummins which certainly wandered too but seemed consistent in the steering wheel angle department. The rear coil spring setup allows the rear to move back and forth under the truck just like the front as it goes through its travel arc just making things worse! Didn't have that problem on the old Cummins.
*Sigh* I need to relax. I'm gonna go have a stiff drink and try to stop hating this stupid "problem" so much...
Rockcrawlindude
Jan 1, 2021
Georgia USA
How much caster and toe are you running?
Lemme guess. Yours does the same thing?
Not this one but some other trucks and jeeps i have had… and the rear track bar keeps things pretty well inline and you dont get much movement side to side i think 4” of travel up and down translates in to 1” sideways movement you get more movement in the tires hitting bumps than that…
jetrinka
Jun 11, 2021
Toe is zero and caster if I remember right was even just above 5 degrees each side. Its not pulling at all - just following crown but its hard to find true center with the drag link is all.
I know you said in another thread your truck drove like garbage on Thuren's specs
Honestly just ignore me lol. I am attempting to fix problems that don't actually exist
Rockcrawlindude
Jan 1, 2021
Georgia USA
That wasnt me, must’ve been somebody else. I’ve never had my truck on an alignment rack and my truck never rode bad.
My truck rides great with the alignment I did in this thread, fox 2.0s and no front sway bar.
