HO vs non-HO MPG
I can create photos like that while rolling downhill after resetting my MPGs so my "Unicorn" can show 20+mpg while making no boost as well. LOL!! It is shocking the amount of Mis-Information on forums but such has been the case since AOL said, "You've Got Mail!"
Please enlighten us with quotes and the correct information.
Sent from my work avoidance device
GPurcell01
Oct 3, 2021
Lone Star State
So what to do moving forward...? I am deleting the truck this week. Installing the Banks 4" intake and going to see what this truck can do working hard without the limitations of the BS installed upon it. If that doesn't help, I will pull the engine and install the non-HO pistons with head studs, re-tune it and get the power it should have at cruise.
Hope this long post helps those see the miles matter... even if you do not drive like I do, they matter in the long run.
Dude if it bothers you that much just trade it in for a SO truck. After doing all that work - parts and labor will still have you in the hole for more than those oh so terrible fuel costs...
New truck would come with the SO cam free of charge*
Jul 27, 2020
You guys are hysterical with your Camshaft needs...
So by your logic, I could trade for a SO truck and then have to spend the money for upgrading the 68RFE, which will cost far more than just deleting the BS and increasing the power/efficiency these trucks should have from the beginning. RAM should offer the Allison as ATS now has the new case to make it fit properly. I will probably do that with the 2015 2500 Laramie Longhorn I just bought and deleted this past week.
MEGA HO
Jul 20, 2020
Alberta
You want to turn HO into SO, but then you would also turn SO into HO. Did I get it right?
Sent from my ONEPLUS A5010 using Tapatalk
Cruising at 8K elevation.
Not going downhill.
This is "in the boost?"
For that matter, what on earth makes anyone think boost decreases fuel mileage when a modern efficient turbo increases MPG?
Of course, pulling a load and adding fuel and higher boost is going to affect MPG, but the point was made that the truck is worse unloaded because "boost."
SMH.
Nd79
Jan 11, 2021
Colorado
Since it's being talked about somewhat, would the cab and chassis trucks provide something similar to a SO Cummins mated to an Aisin trans? I know the cab and chassis are de-rated but I don't know how exactly that works.
MEGA HO
Jul 20, 2020
Alberta
Good question.
But my guess would be it's a derated HO.
19 2500 limited
Sep 19, 2020
Not going downhill.
SMH.
Not going downhill.
SMH.
is yours an HO? 571 to empty with the stock 31 gallon tank on full?, if so that is great!
HO.
50 gal tank and I was using 4x4 and hunting the last 5 days so DTE is wonky for sure. I think tank was down 1/8 or so as I had just filled early that morning and that was at day's end (that day mostly road scouting). It was showing 675 DTE after the morning fill, after 5 days hunting and getting terrible off road MPG.
Nd79
Jan 11, 2021
Colorado
So I just hand calculated my milage today on a tank of fuel with no towing miles/ truck unladen, as I'm in my off season for work. Mix of highway/city driving.
EVIC showed way worse milage because it just completed a Regen before fueling up, plus I had been taking the kids to school here and there with the truck.
I think these Cummins diesels are extremely efficient for how capable they are! HO or SO they are both great and you just pick whatever flavor fits you best. Anything between 15-20 mpg is awesome in trucks this capable. I always laugh at the fact that our new Ram 3500 is our second most fuel efficient vehicle, only behind our little Toyota Corolla.
Hand calculated I came out to 20.4 for this half tank of fuel.
jeffn
Nov 1, 2020
my 3500 DRW with HO and 4.10 gears is never going to see that number. Mileage is going to be over a wide range depending on configuration. I just came back from Florida and 300 gallons of diesel tells me I was getting 10mpg while towing an empty enclosed trailer under the speed limit most of the time.
Cpsram21
May 16, 2020
Idaho
Yep your doing a lot better then my 21 H.O. 3500 ! Mostly city with some highway empty no towing I'm averaging 14.6 hand calculated. But as much as I wish it would get 20mpg I don't drive it a ton and being able to tow anything I want is good enough for me .
jkempken
Nov 30, 2018
I wish I could get that good of fuel economy, but I didn't buy the truck for MPG's. I average around 14-15 Hand calculated with my mixed driving on my 2020 SO. Right around 8- 9 MPG pulling my enclosed trailer at 80. But more importantly where is the diesel price $2.90, everywhere around me its right around $3.50
Nd79
Jan 11, 2021
Colorado
Yep, any time I hook up my trailer mileage cuts in half! Even empty (4.5k)
Nd79
Jan 11, 2021
Colorado
Ha I'm in Colorado and it's the gas station I always hit while I'm working the truck. I usually burn a whole tank in a day when it's busy, so I keep my eyes open and this station is consistently 10-30 and sometimes even 40 cents cheaper than all the surrounding stations. The down side is, it's a relatively small shell station and it's always full of full size (tandem/semi) trucks and guys filling their fuel cells. I've learned to stop in after the morning rush, or before the afternoon rush lol.
gimmie11s
Mar 30, 2021
That's been my experience as well. Empty, my HO/4.10/DRW will get 17 on a good day hand calc'd to a tank. Towing our 14k lb 5er loaded it will get 8.5-9..... about half of what it does empty.
GBB
Jan 4, 2021
I been telling you guys it has something to do when you plug that trailer cord into your truck! Mine does same thing when I plug it in…mileage goes to hell.
Wolfcreek
Dec 3, 2021
I’m in a ‘22 DRW 3500 HO w 373s and I don’t know if I can afford to keep it. Only 1500 miles on it and I’m averaging 13.5 by the display and hand calculated I’m getting 11.5. That’s mixed driving with maybe 60 miles towing. I know these are big powerful trucks but that’s way less than my ‘17 with the same setup. I talked to my dealer thinking something is wrong and he just dismissed it as normal…. Not good with fuel at $4 per gallon!
elephantrider
Hydraulic Lifter Crew
Sep 3, 2019
what is "way less" than your '17? you have 37's on a 1 ton truck. I'd expect 11 to 13.
