FINISHED.........Digital Tow Mode Camera Connection from Bumper to Bed
joeycamp
Feb 22, 2022
Here is how I made the connection between our fifth wheel and truck until I can come up with a more permanent solution. Over 800 miles and doing great. Don't know how I lived without a rear view camera on our trailer this long.
How did you suspend the wire up there like you did? This is mine on a test run in a parking lot. And I mounted my camera above my rear window, I think it's a little too high. Where did you mount yours?
dalesonger
Mar 7, 2024
I have been reading for hours and still cant find where anyone has successfully moved or purchased parts to allow for the connection of the digital rear view for the trailer to the bed of the truck for those of us that have 5th wheels or Gooseneck trailers. Thought I would open up a new post and see if anyone has had success. I have purchased a 10' fakra cable and a 15' TNC RG58 cable to see if it can be added to the 50' cable and maintain image stability, as my setup is a 42' 5th wheel, and I don't think 50' will be enough. Both of these cables work and the image is stable. I personally like the TNC cable as it is more weather resistant and robust compared to the Fakra cable.
Bumper blank part number is 68526870AA ($10.46)
Bumper coax connector
68508681AA ($97.00)
10' Fakra cable - Used for connection on camera side
https://www.amazon.com/gp/product/B07M7TG6V2/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&th=1
15' TNC RG58 cable - Used for connection on truck side
https://www.amazon.com/dp/B00O07116...t_i_093BFMEMPBRKB7ERR5VD?_encoding=UTF8&psc=1
All complete and works Awesome!!!
  1. Remove the entire plug from the bumper (this is done from the back side. Use a flat blade screwdriver and pry up on the metal tabs and it should push through).
  2. Disconnect the Fakra cable from the back of the plug (little tab on the side of the Fakra cable. Just push in and pull).
  3. Under the truck follow the Fakra cable to the bumper brace. There are 2 push pin zip ties holding it in place. Pry up on those to release the cable.
  4. View attachment 32344 Yellow is push pin location and Green is Digital Trailer Rear View (back side of bumper) location.
  5. Route the cable over the frame towards the fender well.
  6. View attachment 32345You can see the 2 push pins (black arrow) and a blue terminator in the picture.
  7. Route the cable to the bed following the yellow arrows in Step 7.
  8. I have not cut the whole yet, as I wanted to make sure the cable was long enough. It is long enough, and this is a picture of the cut I will be doing as well as the cable.
  9. View attachment 32346 Yellow arrow is Fakra cable for Digital Trailer Rear View. Blue arrow shows existing slot in the bed.
  10. View attachment 32347
  11. The measurements for the cuts are:
  12. View attachment 32195
  13. Created a 3d printed spacer as the bed metal is not as thick as the bumper. You can use wood, plastic anything that is 1/4" thick.
  14. View attachment 32348View attachment 32349
  15. View attachment 32350 Spacer installed inside fenderwell (Yellow arrow). Wire tie (Black arrow) for strain relief.
It was an easy fix for those of us that pull 5th wheels and Goosenecks. It took me about an hour to map all this out, and about an hour and a 1/2 of cutting, filing, painting the bare metal, and putting it back together. You can use any material you want to make the spacer, I just have access to a 3D printer, so thought I would use it.
Decided to try a test and connected both the 15' TNC RG58 cable and the 10' Fakra cable to each end of the main cable, so now I have a total of 75' which is more than enough for my 42' 5th wheel.
View attachment 32354 Blue arrow is 10' Fakra Z cable and Yellow arrow is the 15' TNC RG58 cable. Both are listed above.
All looks good with these lengths!
Very nice.. I broke my bumper connector..
Guess I will try and order another..
wonder what the other Fakra connector under the side of the truck along side the one we unplug to move it in side the bed.
Also.. I bought the Amazon extension cable..
