Over that last week I was also able to wrap up the lighting system in the SmartCap. Following in the footsteps of several other builds I monitor on various forums, it turned to HardKorr to meet these needs. Their clean interfaces and flexibility were the main reasons I went with them. For my build I ordered three 48cm (19") light bars for the main cap area and two 25cm (10") light bars, one for each side.
For anyone looking for the info, the cables on the 19" bars are 12" long and about 8" long on the 10" bars.
These light bars come with built in magnets for mounting. You can see them between the black squares along the center line at either end of the bar.
Four of the five bars that I order held really well via the magnets, but one of the 10" bars could barely support its own weight. I thought that was going to less than ideal in the offroad conditions I like to travel in, so I backed each bar with Velco. The Velco I had was a little too wide, so it had to be trimmed down to fit the width of the bar with a sharp razor blade.
With the bars all prepped it was just a matter of mounting them where I wanted them and then running the cables back to the electrical half bin. The light bars are designed to use a cigarette light for power, so I had to chop those off to hard wire them into the Blue Sea Systems fuse block that I installed during this processes.
I'm not 100% happy with some of the wiring, so I'll most like redo those parts when I have some more time. Otherwise, I'm pretty happy with the clean install and location of the controllers for each of the three sets of lights.
