As mentioned above, my RSI SmartCap arrived this past Friday and we installed it on Saturday. The build and install was pretty straight forward and there were just two "tricky" parts on assembling it. Both were on the rear panel where getting the tabs to align with the slots was kind of a pain. One person had to lift up on the rear panel and at the same time push down on the side panel. The second person had to insert the hardware to lock it all into place.
It some in two very large boxes.
I did not get the built in table, so my roof just has the eight rivnuts in it. Those will come in handing for mounting something down the road I'm sure.
Some of the slots had a bend in them. At first I thought this was some type of damage, but the side panels had the "dents" in the exact same place. This makes me think they are from the manufacturing process. These did make it harder to insert the hardware into these slots.
Speaking of hardware, when you take the hardware out of the front and rear panels, do your self a favor and take the black space pieces off and tape the silver metal plates to them. This makes things a lot less fiddly when you are holding the panels together and trying to install the hardware.
While putting this thing together you will notice that they did not skimp on the details. They even cut the part names into the parts. Each panel is also paired to the others with a hand written set number.
Assembly is as simple as Insert Tab A into Slot B and then bolt it down.
The fully assembled SmartCap is pretty heavy. Two guys can pick it up off the floor, but would be hard pressed to lift it high enough to get on the truck... let alone have enough control to do it without damaging anything. I only had two buddies to help me, so we used my Jeep top/RTT hoist to lift it up and then backed the truck under it. That worked out great. We spread the load of the top across all eight M8x1.25 nuts in the built in rails.
And here it is installed on the truck.
