Thank you bud. Yep, I did the same searching and wasn't finding everything I wanted in an all-in-one solution that used good components so I decided to make one. A lot of research to make sure every piece was rated correctly for the amps, heat environment, and of course to take full advantage of the aux switches and available pass throughs and understand its capabilities. Mind numbing hours of reading factory wiring diagrams and researching wire strand counts and insulation types, sourcing the right Yakazi terminals and wire seals etc lol. Ram has a really superior system compared to my last experience with Ford HD, especially the use of pass throughs, I've used all 6 switches and all 8 ports and have ample access in-cab for battery power, ignition power and ground to tap into as needed in the future, same for at the rear of truck and really easy access to swap things around as needed in the distribution box and really dial in the correct fuse rating needed for each accessory I added, I really wasn't keen on having a $400 light bar (and the effort required to uninstall and replace it) on a fuse that was too big to protect it and sloppy in-line fuses weren't the direction I wanted to go.@44Dan44 I looked hard thinking there is no way this wasn't a kit, but I searched and could not find anything. Did you put this distribution box together?! Do you have a parts list?? Awesome work, your **** is insane and I love it!!
I have a notion to sell a complete tip to tail, custom labeled kit on FB, maybe I should lol.
