It almost looks like the Tradesman grill has less surface area to restrict air vs the Bighorn and above grills.Installed the Rough Country 1500 Grille lights. It was an all day lollypop of a project but I love it. Full how-to details at https://hdrams.com/forum/index.php?threads/grille-lights-from-rough-country.11979/post-265002
Saved all the wiring for last. I'll be making all my connections on Aux 1-4 on the front. Stay tuned for that. A bunch of mowing needs to happen first.
Aux 1. MandR Light Bar
Aux 2. Fog Lights
Aux 3. RC Grille Lights
Aux 4. Front mounted electric Train Horn
Aux 5. Rear mounted electric Train Horn (too high of an Amp draw for one switch)
Aux 6. Auxiliary rear/reverse lights
Get ready to work dual alternators
Don't know for sure. Could be, I prefer the look of the Tradesman grille, I'm sure it was discussed at length in 2019 but I don't know the reason for, or like the appearance of, the indentation on other trims??? If anyone knows if there is a reason for it please tell me.It almost looks like the Tradesman grill has less surface area to restrict air vs the Bighorn and above grills.
I wonder if that is true?
I personally don’t like the chrome version at all, but the bighorn version is good.Don't know for sure. Could be, I prefer the look of the Tradesman grille, I'm sure it was discussed at length in 2019 but I don't know the reason for, or like the appearance of, the indentation on other trims??? If anyone knows if there is a reason for it please tell me.
How bad was the modifications to get the 1500 grill lights to fit? I really want these but have been hesitant to tackle the job!
Got a shot full dark this time.Mounted these up, 8,000 lumen for the pair. I like the length vs a cube size/style light. The provided brackets can be used 2 ways, I chose the orientation that results in nearly a flush mount.
For the look, the price, the warranty, I don't think you can beat these.
Powered via Aux 6 / Red/White/ Battery
A decent harness with relay/switch/fuse/etc is included, chopped up and just used the connectors at the lights.
I have them aimed higher rather than ground focused, happy with the resulting light spray.
Impressive!Installed the Rough Country 1500 Grille lights. It was an all day lollypop of a project but I love it. Full how-to details at https://hdrams.com/forum/index.php?threads/grille-lights-from-rough-country.11979/post-265002
Aux 2. Fog Lights
Amazing
You would have to cut much more structure when installing. If you looked at the install pics thread I am referring to cutting the high side to be the same height as the short side. That would get you a lot of adjustability. It’s do-able….. but, not going to be adjustable after the fact, meaning, set them where you think you might want them, reinstall grille, pull grille back off to adjust again. So during the install before you completely put it all back together, grille on and off is easy if you’ve planned ahead with a quick disconnect for wiring. The tightening of the screws that hold the light to the faceplate (and allow for adjustment) are not accessible after grille is installed.Amazing
Do you think there is a way to aim them down any?
For more adjustability vs locked in place.You would have to cut much more structure when installing. If you looked at the install pics thread I am referring to cutting the high side to be the same height as the short side. That would get you a lot of adjustability. It’s do-able….. but, not going to be adjustable after the fact, meaning, set them where you think you might want them, reinstall grille, pull grille back off to adjust again. So during the install before you completely put it all back together, grille on and off is easy if you’ve planned ahead with a quick disconnect for wiring. The tightening of the screws that hold the light to the faceplate (and allow for adjustment) are not accessible after grille is installed.
Long throw. Pleased.Testing before closing it up.
It's in. Night shots this weekend.
View attachment 57991View attachment 57992
Final notes, love it. Overall easy install, lifetime warranty.
