CP4 recall thread (merged threads) - Y78 Jan 2022 recall campaign - Parts Available May 10 for 2020 trucks only
Cummins3
Nov 23, 2019
I just got a email from nhtsa
I sold my rammer but wanted to share this information
NHTSA Recall ID Number : 21V880
Manufacturer : Chrysler (FCA US, LLC)
Subject : High Pressure Fuel Pump May Fail
Make Model Model Years
RAM 2500 2019-2020
RAM 3500 2019-2020
RAM 4500 2019-2020
RAM 5500 2019-2020
Not sure what the fix is but this is good news
Sent from my SM-G965U using Tapatalk
[MOD: Compliments of @Jimmy07 :]
Here’s two advanced communications for it:
Revised TSB for CP4 failure replacement kit with CP3.3 pump retrofit: https://drive.google.com/file/d/1MQAFhqEr5mnCJ1VzIjOQBHzcqSEV260H/view
[MOD: CP3.3 retrofit kit]
index.php
New pump tag: CR/CP-ISB19S3/R110/30-789S
( 21+ tag is CR/CP-ISB21S3/R110/30-789S
Base Y78 Recall pump kit:
Full failure mode additional parts:
clawdog79
Feb 13, 2020
I received it as well. I already did the CP3 swap earlier this year so I’m probably SOL but at least I’ve been driving my truck worry free for several months.
Burton12387
Oct 15, 2019
Central Illinois
Never mind, I see the pdf shared in the cp4 service solutions thread. Thanks.
GPurcell01
Oct 3, 2021
Lone Star State
Just read an article that 2019-2020 trucks will be issued recalls for the fuel pump. The fix is to replace it. No idea which pump though. Ram/Stellantis acknowledged the recall today. Notification for the recall will roll out starting Jan. 1st
Omarf4
Jul 2, 2019
anyone know how long it takes for a HPFP to be replaced, assuming all parts needed are there?
RPS1030
Mar 29, 2020
SW UT
Depends on if it's a replacement or a upgrade (hopefully).
When mine failed on a Sunday, I got it back on Saturday with new pump, lines, and in-tank pump. So a day of labor after approval.
Changing to the "CP3" will probably be a little more involved since mounting and front covers are different. But still a full couple days I'd guess.
That note about "repurchase engine" might imply that FCA has considered full engine replacements being easier for dealerships to swap vs doing front covers and such, then do retrofit/reman at another facility.
ETA: I've seen mention of HPFP filter screen and engines being inspected for POSSIBLE replacement due to suspect damage.
Until these start happening, it's still a lot of speculation what will actually be replaced in the recall.
sisupower
Aug 30, 2020
Yeah everyone is freaking out and calling the dealer. Dealers don’t know anymore than us
DontSlamMyRam
Dec 30, 2019
And I Think to Myself, What a Wonderful World. The CP4 in my truck was so sh*tty, but after the recall a CP3 will be so Pretty. No more diesel woes, I'll finally have truck that tows..
hpc3
Jul 4, 2020
Just found out today, first oil/filter change in my '19 3500 Std. Its added to the list for whatever the TSB/replacement action is now. Knock on wood no issues to mention on mine so far... other than the dealership whacking the antenna and one of the clearance lights by running it through a "Car" wash just before I took delivery.
Lumpskie
Nov 11, 2021
What's the best way to find out if my truck is included in the recall? (I have a 2020 2500) I thought I saw somewhere a website that you could put your VIN into...
