I working on it, i just waiting for the aux fuse box from mopar, to see i already install the switches and enable comercial options see what happens.
You did it?You're going to need to run wiring from connection below the knee panel (for lack of better term) into the engine bay at the fuse box for it to work.
Hello, I am new the sight. I have a 2019 Ram 2500 limited. I do have the PDC fuse block and I have ordered the switches from the dealership. Do I need to order the wiring harness too?I bought F/R Fab Four bumper for my truck and wanted to add the Aux switches to wire F/R led lights. Since no kit is available for the 19's I started researching parts and have the electrical part connectors in route to fit the oem PDC box, as you all know Ram has installed the PDC relay box in the 19's as part of the wiring harness wiring dash Left but did not include the wiring on trucks with no Aux switches. It's only wired for the cab heater on the diesel and no room to add another relay box in that area. I downloaded the service manual from tech authority and have made sense of all the wiring connection to the PDC and such.
I plan on wiring my truck using the oem PDC box but the problem as of yet is the Instrument Panel Switch that will fit my truck Tow/Haul Exhaust Brake, Park Front/Rear and 6 Aux switches won't be available till mid February. For some odd reason Ram has no inventory of the switches as they are all going into trucks being built. So I will get it all wired up and wait for the switch to show up. I have had my PDC box all apart and should not be that hard to do with some knowledge.
Should be able to add Aux switches to a Power Wagon as well, but not sure on the exhaust brake/traction control switch function on the switch as my truck has the traction control up on the MODULE-INTEGRATED CENTER STACK SWITCH BANK with the Hazard above the radio.
I will have F/R white painted bumper from my truck if anyone is interested when I get the front installed when it shows up mid January.
You did it?
I have seen guys run wires thru this plastic block off plate, I believe its for a clutch master cylinder block off plate. I sent all the parts I had to paulvi but he informed me today it got delivered to his house on a Airforce base but looks like someone may have taken it off his porch while he was at work. I hope he finds the box as there is alot of parts in there to put kits together, I have sent him all the drawings and wiring schematics I had.So now this thread dies with BighornHDRam giving in to Ram's crappy customer service. Don't blame you at all. But I was just looking to see if there's any other way to get my own wiring through the firewall or around it to put my new toggle switches in the cab for my light-bar and accessory lights? Does anyone have an idea of where to feed the wires through???
I saw the switches on the build web site for 3500 they were a 145 option which I added too my truck .
Same hereWhen I ordered, clearance lights were also a $95 standalone option.
Or buy a Power Wagon...When I ordered, clearance lights were also a $95 standalone option.
Hey they should give you something in exchange for payload.Or buy a Power Wagon...
Since I have applied for lemon law on my truck and once it's gone I never plan to buy a Ram ever again after how I was treated, so If any of you that want all the connectors to wire the OEM PDC box here's your chance and maybe sell a few. I can provide you a drawing I created in solidworks as to where all the wires go in the oem pdc box. All these parts took me about 2 months to figure out. I forgot I have 6 68298547AA OEM RAM RELAYS and 11 20a fuses, 2 30a fuses
I have about $850 into all the terminals and wiring 20 TXL, 18 GXL, 12 GXL, 10 GXL, if someone wants it make me an offer for the whole lot only.
You could message member @paulvi and he could build you a kit with all the parts I sold him and you could have the aux switches for your truck as he should enough parts to make a few extra's form what I sold him. He made a new schematic he provided to a couple guys he sold kits to I believe on facebook he told me.Any chance that you could share that schematic to give a starting point for people who want to do this mod as well?
You will have to search for a Tradesman truck that does not have park sensors but has the aux switches on a dealer lot and get the vin and go to your dealer and get that part # for the switch panel.I realize now the part number was posted, sorry about that. Is their a switch panel that doesn’t not required have the Parking sensors?
