Hey
@Jimmy07,
Just some background for how the signature lights behaved prior to changing the two new settings..... when I change "CBC Extern Light Calibr: Signature Light Present" to "NO", the signature lights go off right away and remain off after cycling the ignition to "OFF" for 30 seconds.
When I changed the other two settings to "NO", the error codes were not set, but the signature lights stayed ON. After cycling the ignition "OFF" for 30 seconds, the lights still stayed ON. I tried switching the settings back and forth a couple of times with the same result.
So the new settings fixed the error codes, but the lights aren't turned off.
I have not driving around for awhile with all three set to "NO" to see if anything changes. Do you think it would matter?
Thanks.
