Bump
Okay. "Will it work on 2020 tradesman?"Why are you bumping an old thread you've not participated in?
Use the Watch thread button. If you have a question, ask.
Please don't do that again.
@g00fy I have a 7” Evic from a 2021 Powerwagon in my 2022 Tradesman. The build sheet from the powerwagon specifcally stated it had the off road pages, now if that meant in the Evic or radio I don’t know. But so far no luck enabling the Evic off road pages after installing it in my truck. Off road capable and off road pages set to yes in alfaobd. Any idea of another setting that may need enabling to get the Evic to show the page?You need to have a 2021+ cluster to get the off-road pages in the EVIC. I put a 2021 cluster in my 2019 and the off-road pages showed up, but they still need a newer airbag module in order to get the signals for the pitch and roll gauges to work.
You would need the 21 BCM aswell if im not mistaken@g00fy I have a 7” Evic from a 2021 Powerwagon in my 2022 Tradesman. The build sheet from the powerwagon specifcally stated it had the off road pages, now if that meant in the Evic or radio I don’t know. But so far no luck enabling the Evic off road pages after installing it in my truck. Off road capable and off road pages set to yes in alfaobd. Any idea of another setting that may need enabling to get the Evic to show the page?
I am not getting it in UConnect no, but I only have the tiny 3.5" or whatever basic radio screen.
Maybe (and you may know this already) enabling the setting in AlfaOBD tells the UConnect 8" or 12" radios to display off road pages, which in turn tell the 7" EVICs to display the Off Road Pages? So as I don't have the correct UConnect I am not seeing the EVIC pages? I thought I may be able to enable the config and get the pages in the EVIC at least.
Where did you go to enable it. I have them and want to disable them they are messing with my tuner gauges locking them up because it’s looking for the same info that these damn off road pages are looking for.The pages are part of the radio programming. They don't exist in the software before 2019 on the 12 inch uconnect 4c unit.
I have "enabled" them using Alpha ODB but they don't show up since they don't exist in the software.
It appears the only way to get them would be to upgrade your radio.
Where did you do that on alpha I want to disable mine.For what it's worth- flipping the Off road capable and off road pages via AlfaOBD did not make the off road page available on the 8.4" UConnect screen on my 2022 Laramie. I do not have navigation or the offroad package.
I can see the offroad info on the 7" cluster EVIC. I haven't heard of anyone in my situation figuring out how to make them available on the UConnect screen though.
That should not be an issue though… sounds like the tuner is the issueWhere did you go to enable it. I have them and want to disable them they are messing with my tuner gauges locking them up because it’s looking for the same info that these damn off road pages are looking for.
Nope definitely the radio issue the off road pages are pulling gauge info at the same time mm3 knows the issue and they had a guy fox the problem by doing something with the radio. I am pretty sure this is what it is due to the off road pages gauge’s pulling same info as the tuner. Got a new one from mm3 and same issue due to the fact I fought I am paying for live data and I’m not getting it. So I just need to know how people enabled it so I can disable it I don’t use itThat should not be an issue though… sounds like the tuner is the issue
VehConfig 5: Off-Road Pages Present- NONope definitely the radio issue the off road pages are pulling gauge info at the same time mm3 knows the issue and they had a guy fox the problem by doing something with the radio. I am pretty sure this is what it is due to the off road pages gauge’s pulling same info as the tuner. Got a new one from mm3 and same issue due to the fact I fought I am paying for live data and I’m not getting it. So I just need to know how people enabled it so I can disable it I don’t use it
Just curious if there was any update on this working only on the 12" Uconnect.I assume that 34.x.x firmware is only relevant to the 12” screen….Anyone been able to add the offroad pages to an 8.4?
View attachment 30760View attachment 30761
