fmixman
Sep 16, 2022
Hi all, keeping this alive I am curious if anyone. has sorted a question I have. And I did plenty of search foo for weeks, so if it's been answered I apologize.
I understand the difference between the rearview mirror cam and the 12-pin ( right side of the plate) analog Aux 1 and Aux 2 setup. and then a separate option that allowed for a surround trailer view, which we will not confuse with a truck surround view. ;')
So, now that is out of the way. My question revolves around the analog 2-cam 12-pin setup. 1- does anyone else find offense with Mopar wanting $1300.00 for this? and 2- Has anyone found a custom harness that allows for the use of a better-quality cam? Since I also read the Mopar setup looks like poo for $1300.00. My goal is to have a camera on the back of my enclosed trailer that shows up on my 8.4 radio looks decent and doesn't cost 1/3 the price of the trailer.
In your research, I would expect you found numerous references to using the FORD 12-pin factory harness to build a custom harness. Readily available. Ford PN: HC3Z-14B242-F
fmixman
Sep 16, 2022
I have seen the reference yes, thank you. Have you successfully used this? I don't see anything on - are pins the same and its plug n play? or do we need to repin? Has anyone used a specific cam? do we need to use the Ford camera?
Interestingly enough, your part number led me to this- https://www.tascaparts.com/oem-part...9f?c=bT0xJmw9MSZuPVJlY29tbWVuZGVkIFByb2R1Y3Rz
That seems like the entire single-cam kit from Ford. essentially the same thing Mopar is asking $1300.00 for.
Texasram1
Jan 11, 2022
I just tried to order 68527599AA for my 2022 2500 Limited via store.mopar.com. The order went through, but 15min later I received an email stating that it was not compatible with my VIN. 3C6UR5TL8NG217395
This doesnt seem correct. How can I verify?
Jimmy07
Re-coding from an easy-chair
Apr 5, 2020
Never use a VIN when you order parts
fmixman
Sep 16, 2022
you having a DRVM and having a second cam input for it are 2 different things. if you don't have a plug to the left side of your license plate out back, chances are you will not be able to use that kit.
Texasram1
Jan 11, 2022
I do have the plug
Texasram1
Jan 11, 2022
So plug and play? Local dealer just said i’d likely need the truck reprogrammed for the camera to work?!
Texasram1
Jan 11, 2022
Meaning they are trying to charge me for nothing or it really needs to be reprogrammed so they can get their loot?
fmixman
Sep 16, 2022
to be clear I DO NOT have the fancy DRVM. was one of the no-no's when I ordered. so I don't know the steps. one of these fine folks needs to chime in.
ATCavi8or
Apr 26, 2024
It took me 3 days to read every single post on this thread, wow that’s a lot of reading. The reason I found this thread is because I just ordered a 2024 Ram 3500 with all the tow tech available. I also have a new 40’ 5th wheel that I will take delivery of in a couple weeks and want to install the trailer surround and the rear view cameras. Now, despite reading and comprehending every post here, I am unsure if I’m actually receiving the rear view camera itself. When I went through the builder on the Ram site I tried adding the Tow Mode Digital Rearview Mirror package which says it comes with the wired tow mode camera. However, that then removes the Towing Technology Plus group which is the Digital Rearview Mirror with Side Cameras and the Trailer Reverse Steering Control. Obviously the mirror is redundant which is probably why you can have one or the other, but the Tow Technology Plus Group has no mention if it comes with the wired tow mode camera or not. I have attached my build sheet and the code XH7 is not there which from what I have gathered is what gives you the actual camera. According to the info on the Trailer Towing Technology Group (not the Plus), which includes Trailer Reverse Guidance it says “a loose shipped rear view camera is also available for upfit installation“. The big question is what does “available” mean? Does it mean included or just that it can be purchased separately? When I placed the order with the dealer I didn’t even think to ask because I assumed it would be included but now I’m not sure at all. I guess I’ll find out in a couple months when I can take delivery of the truck. Of course I’m sure it will be impossible to obtain one if it isn’t included.
  • Ram3500 Order.pdf
ATCavi8or
Apr 26, 2024
Also, @gator6 mentioned an RG58 extension cable he used but never linked to it. Does anyone know which cable he used?
