The truck made it from Nashville to South of Orlando fine. Shifting was not good 1 through 4. Nearly turned around but wanted it at a closer dealer. Drive about 400 miles. Stopped for food and fuel was better than before when I took off but still not great. Drove 350 miles and made it here. Took it to the car wash this morning and id say the shifting has gotten about to the acceptable point. It must take heat then a key cycle for trans ecm make changes to shift calibrations.
Ok if you get me this info I’ll add it to the spreadsheet:
1. Date you ordered the truck (if applicable)
2. Date of manufacture (See sticker on driver door for "date of manufacture (Build date))
3. Date you purchased the truck
4. Mileage on odometer at the time of failure
5. Serial Number of failed transmission (see blue stamped metal tag on side of the transmission. It will be something like "2H-2345"
6. Serial Number of replacement transmission (if applicable)
7. Were you towing at the time of failure?
8. Did 1st through 4th gear work?
9. Did reverse work?
10. What date did the transmission fail?
11. When was the truck returned to you after repair?
12. Did your dealer replace the transmission with a new unit or was the failed transmission repaired with parts?
13. Was / Is the truck currently identified under Customer Satisfaction Notification 71A?
