SPIED: Multiple Ram Heavy Dutys Caught Testing:
Several Different Trim Models...
Thanks to our friends at Real Fast Fotography we have a bunch of new 2020 Ram HD pictures to share with you. Caught again are the Tradesman trim regular and crew cab with the 8 foot box and we also have photos of the Laramie crew cab with the 6’4 box. It appears that the HD models are following the 2019 Ram 1500s lighting philosophy with the Tradesman models having halogen headlights while the Laramie has reflector LED headlights. Expect LED headlights to be an option on the Big Horn trim level and standard on Laramie and above.
Expect Longhorn and Limited heavy duties to have yet another headlight setup incorporating projector LEDs as they do in the 2019 1500s. We do know that the headlights will be a completely different shape as the HDs are getting a different front end than the 1500s. The Grille inserts are similar to those of the 2019 1500, but we expect the grille to be a completely different shape, the crosshair grille is gone, but we can see an indentation down the middle of the grille like on some 1500’s that is a bit of a “reverse crosshair” design. Expect all models to have the RAM lettering in the grille as opposed to the Rams head badge.
We also received some photos of the backs of the Tradesman and Laramie trucks showing the differences in taillights between the 2 trims. Expect the HD’s to have the same taillights as the 2019 1500s with incandescent on the lower trims and LED standard on the higher trims and optional on the Big Horn. Our full gallery is below as well as a link to our article “Everything we know about the 2020 Ram HDs.” We expect to see the 2020 Ram HD unveiled at the North American International Autoshow in Detroit, next January.
