RECALL: Ram Recalls 142,150 Fourth-Gen Trucks For SCCM
High-Beams May Turn On When Turn Signal Is Activated...
Stellantis (FCA US, LLC) is recalling 142,150 units of its fourth-generation Ram Trucks for a steering column control module issue.
FCA US, LLC has announced a safety recall on a specific 2023 Ram 1500 Classic (DS), Ram 3500 10K Chassis Cab (DF), as well as 2023 and 2024 Ram 2500 (DJ), Ram 3500 (D2), Ram 3500 Chassis Cab (DD), and Ram 4500/5500 Chassis Cab (DP) vehicles.
Some of the above vehicles may have been built with a steering column control module (“SCCM”) turn signal self-canceling anti-jam component out of specification or an internal short circuit on the SCCM printed circuit board (“PCB”).
The steering column control module may cause the high beams to activate when the turn signal is used or activate the turn signal when the high beams are used. In addition, the turn signal self-canceling feature may not function properly. As such, these vehicles fail to comply with Federal Motor Vehicle Safety Standard (FMVSS) No. 108 requirements, “Lamps, Reflective Devices, and Associated Equipment.”
A turn signal that remains active after a completed turn may cause surrounding drivers to misunderstand the intent to change vehicle direction. High beam activation when the turn signal switch is activated may reduce oncoming drivers’ visibility. Either of these conditions may cause a vehicle crash without prior warning.
FCA US, LLC Recall B2A Affected Units |
Model |
Affected Production Dates |
# Of Affected Units |
| Ram 1500 Classic (DS) | 9/19/2022 to 6/2/2023 | 23,030 |
| Ram 2500 (DJ) | 6/21/2022 to 7/21/2023 | 73,739 |
| Ram 3500 (D2) | 6/21/2022 to 7/21/2023 | 25,799 |
| Ram 3500 Chassis Cab (DD) | 9/19/2022 to 6/2/2023 | 6,007 |
| Ram 3500 10K Chassis Cab (DF) | 12/7/2022 to 6/29/2023 | 142 |
| Ram 4500/5500 Chassis Cab (DP) | 11/18/2022 to 7/21/2023 | 13,433 |
Recall Chronology :
- On May 4, 2023, the FCA US LLC (“FCA US”) Technical Safety and Regulatory Compliance (“TSRC”) organization was notified of a potential issue related to malfunctioning SCCMs on some 2023-2024 MY Ram Heavy Duty and Ram 1500 Classic vehicles.
- From May 2023 through October 2023, FCA US TSRC analyzed SCCM failure patterns and vehicle history and determined that the affected vehicles may have been built with SCCMs, which may not function as intended.
- On October 18, 2023, the FCA US TSRC organization recognized a vehicle build issue existed on certain vehicles related to a condition that can lead to failure of turn signal self-canceling or turn signal activation when high beam requested or vice versa, potentially resulting in a noncompliance with FMVSS No. 108.
- On November 21, 2023, FCA US determined, through the Vehicle Regulations Committee, to conduct a voluntary safety recall of the affected vehicles.
Dealers will inspect and, if necessary, replace the steering column control module free of charge. Owner notification letters are expected to be mailed on January 17th, 2024. Owners may contact FCA US, LLC customer service at 1-800-853-1403. FCA US, LLC’s number for this recall is B2A.
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153) or visit www.nhtsa.gov.
