22PearlRamMegaHD
What are your thoughts on Genos? Appears their stuff is all OEMTheir stuff has been proven to be subpar and problematic over the past few years. If you take the time to compare their products with those from the OEM filter manufacturers (Fleetguard and Parker-Hannifin / Baldwin) it’s not very difficult to see the difference in quality of construction. If you take the time to cut their filters open and compare to the OEM there’s no comparison between the two. I’ve also replaced several of their primary fuel filters on 2018 and older trucks, which caused no-start conditions or at the very least low fuel pressure codes due to poor construction. I’ve also seen several of their engine oil filters where the media separated from the canister internally. The quality difference between Docs and OEM is sufficient enough that I avoid them. In truth, if you take the time to source the OEM filters directly from their manufacturers distributors (not Ram Dealers), the price difference isn’t worth going outside of OEM. I can buy both OEM fuel filters, a better oil filter than OEM, and the same engine air filter for $180 at my local International trucks dealership which is one mile from my house. Compared to the $120 docs charges for subpar products and cheaper quality. That $60 savings isn’t worth it when it comes to maintenance on a $100k vehicle. Geno’s garage also offers a very reasonably priced OEM filter kit ($175 for the four filters I mentioned) I also find it very interesting that Doc’s does everything in their power to systematically eradicate any negative reviews or comments attached to their products. I wonder why that is? View attachment 73517
Mopar Quick Service Filter Kit for 2019-2024 Ram 6.7L
Get genuine Mopar OEM filters for your 19-24 Ram 2500/3500/4500/5500 6.7L Cummins. This Quick Service Kit includes air, oil, and both fuel filters for one complete filter change.
www.genosgarage.com
