Archoil went into a fresh tank of fuel tonight
My DPF % REG is sitting at 97% on the iDash so it’ll go into regeneration tomorrow. I’m seeing pretty rapid rises in that PID, sometimes so fast it doesn’t even seem plausible in reality. If the truck is running that “dirty” there would have to be significant excessive fuel or lack of air issue. Definitely lends more credibility to the sensor / programming theory being at fault for these frequent regenerations. I’m currently at 239 miles and about 6 engine hours since the last active regen cycle completed. Itll be in regen tomorrow before reaching 300 miles, so my frequency is definitely getting worse. 474,496,331, and this one likely to be sub-300. 14, 11, 8, and now likely about 6 hours.
I took some time to do some investigating in the engine bay. Wanted to inspect the MAP sensor. As suspected it was soot-laden. I cleaned as best I could with CRC MAF sensor cleaner, however a lot of the soot remained. I didn’t want to attempt any physical contact with the sensor, so just used the spray as best I could and then reinstalled. No noticeable change in performance.
The IAT sensor was clean and looked like new. I elected not to mess with the MAF, as I didn’t have the time to do a relearn drive cycle if it started to cause issues. In talking with some really good Ram techs, my truck has the MAF that they’ve been changing out for the newer one.
