E file form 4 individual or trust?My Gemtech got out of jail today. A little over 6 months for the paperwork.
Individual.E file form 4 individual or trust?
@Brutal_HO knows better than me. Surefire just came out with a new flow through that’s supposed to be awesome. Flow through is the new hotness it seems. Huxworx used to be OSS and I believe they invented flow through suppressors.I'm very new to the suppressor game. What brand should I look for if I wanted one for an AR?
I figure I can use my Gemtech on my HK and move it over on to a 1911. Just have an adapter for the HK.@Brutal_HO knows better than me. Surefire just came out with a new flow through that’s supposed to be awesome. Flow through is the new hotness it seems. Huxworx used to be OSS and I believe they invented flow through suppressors.
I went with a wolfman to run on multiple calibers as it can handle 9mm or 5.56 and everything in between with some tradeoffs compared to a dedicated caliber can.
Depends on what you want from the can, I suppose.I figure I can use my Gemtech on my HK and move it over on to a 1911. Just have an adapter for the HK.
I like the idea of the Wolfman. Time to go down the rabbit hole and see what I can learn.
Thanks for the info.
Need a 1/2” x 28 to 1/2” x 24 bushing to install the hearing protector on my AR-9. Amazon has lots of options. Any reason to spend more $$ or just get any one that works ???
I was assuming that because it currently has a standard A2 flash hider on it that it would be 1/2-28. The hearing protector is 5/8-24?
1/2-28 to 5/8-24?
or maybe 1/2-28 to 1/2-36?
What do you have that is 1/2-24?
Most 9mm carbine barrels will be 1/2-36.
Suppressor Thread Size: Common Barrel Thread Patterns – Silencer Central
Your guide to the most common barrel thread pitches in handguns, pistol caliber carbines, and rifles. Need your barrel precision-threaded? Contact us today!www.silencercentral.com
The muzzle thread on my AR-9 is indeed 1/2”x28 so I go back to my original question. I need the bushing for 5/8”x24. Are all bushings created equal or should I get one of the more expensive ones. ThanksI’ll have to check the threads now. I might have the right thread gauge for that. If not I’ll pull the A2 flash hider off another AR and compare.
Saw this the other day and almost laughed coffee out my nose hahaha
I don’t know anything about them but my mantra is always buy once cry once LOLThe muzzle thread on my AR-9 is indeed 1/2”x28 so I go back to my original question. I need the bushing for 5/8”x24. Are all bushings created equal or should I get one of the more expensive ones. Thanks
I’ve always heard there is no such thing as a drop in part for a 1911.So got the Wilson combat "drop in" beavertail grip safety. So much for "drop in".
It was .070 wider and .080 longer than the original one. Would not fit in the frame. Had to do a bunch of filing, sanding, profiling and polishing to get it to fit. Once in, only a few strokes of the file to get it to mesh with the trigger bow and work good. Then I had to do some sanding/contouring to make it fit the frame perfect.
THEN I had to figure out the bluing. But it came out good .
View attachment 66120View attachment 66121
