When is the facelift coming out?
brv10
has the scoop
Jun 13, 2021
We have only put ZF's in for Cummins
mbarber84
Sep 10, 2021
Washington County, PA
I was shocked ZF let PACCAR “rebrand” it. But I guess if you pay enough $$, you can call it whatever you want. PACCAR is a strange animal. They did the same “rebranding” with some Cummins engines as well. Not sure what the allure is by doing that.
If the transmission is indeed the Powerline, it will absolutely have auto park. The park lock is rated at 33k GCW.
If anyone wants to see some “features” of the transmission, you can go here:
The transmission has been on the road for a little while now, as PACCAR has been installing them in their medium duty trucks under the disguise of the “PACCAR TX-8”.
Side note: check out that column shifter ;)
They flyer says auto park with engine off, which is better than how the current auto park works.
mbarber84
Sep 10, 2021
All the lit on the ZF Powerline shows the same.
I’m curious to find out how they’re going to play the horsepower and torque numbers. ZF’s documents say 1,000 lb / ft of input torque max. We’re already slightly above that in the HO, and if they want to continue to battle it out in the numbers war, they’re going to have to squeeze a little more juice out somewhere.
The Paccar says 1050, so it’s closer.
I’d guess it’s going to be at least 1200.
I've said this before but here goes.
I love my HO/AISIN but wouldn't mind seeing an 8 or 9 speed ZF Powerline that is overbuilt and can hold 600HP and 1300 lb. ft. in stock form. The no load 2nd gear starts, up/down skip shifts, neutral idle, and rolling D/R/D looks really great on paper.
Yup.
Units
Nov 17, 2023
South Ms.
Guess in a few years when the kinks are worked out, I’ll have to trade up to get the 8 speed. I’ll wait to break that news to wife till the last minute.:cool:
Units
Nov 17, 2023
South Ms.
I do wonder though, will they make everyone use the knob shifter? I like my old school column shifter, I never did care for the knob shifter.
superjoe83
Jan 24, 2022
The new Ford half tons at work have a column shifter but it's fully electronic, no cable. So I would think ram could do the same thing to keep it on the column. But most likely they will have the knob
That would be a big adjustment for plowing lol i dont hate the knob but its just not ideal for certain applications
brv10
has the scoop
Jun 13, 2021
My last 3 trucks have had the knob, after 10 years you get used to it.
KneeDeep
Jan 29, 2022
My Jeep has the knob and when I get out of one of my Rams I am always reaching for the lever.
