This ^Here is a good read on tire fitment and wheel offset.
2014-2022 RAM 2500 TIRE AND WHEEL FITMENT
Choose the right wheel and tire combo for fender clearance, especially with 0-3 inch lifts. Learn why our setup works best for durability and performance. #WheelandTireCombo #ThurenFabrication #TruckModswww.thurenfabrication.com
Thanks. Definitely didnt order wrong wheels. Got what i wanted. Will put whatever size lift that is needed to make work. Wouldnt be first new truck that i have used a hammer and saw on. LolThis ^
I wasn’t gonna tell him that he ordered the wrong wheels and should’ve researched before buying rather than after. I’m trying to be a nicer person.
Appreciate it. Actually looked at the gallery. That is where I actually ordered my tires and wheels. But by all the pictures appears they will fit maybe with just alittle rubbing. I was kinda more curious if anyone had similar sizes and actual results.There are quite a few examples of __x10 with negative offset -16 up to -44 on the custom offset gallery. Check it out. Should give you an idea of how much poke you’ll have and they list if they had to trim or not
Those would stick out a lot. About 4” more than stock wheelsis that a 35x12.5 on the wheels you mentioned? 18x10 with -24mm offset ? also, would be curious to see a view that shows just how much they stick out (from the front to the side, where you can see the front and back tire) thanks
I will get you a picture. They do stick out alot. But its what i was looking for. They still stick past the fender flares. But i personally hate the look of trucks with fender flares and the tires are way inside of them. I prefer them outside.is that a 35x12.5 on the wheels you mentioned? 18x10 with -24mm offset ? also, would be curious to see a view that shows just how much they stick out (from the front to the side, where you can see the front and back tire) thanks
Good explanation! I had not even thought about the wider wheels sticks out about 4" more inches, but the centerline of the tire sticks out about 3" more... Personally, I would love to see a 18x10" wheel for the Rams with 32mm positive offset. this would allow running a 35x12.50 without rubbing the radius arm and without sticking out too far.Those would stick out a lot. About 4” more than stock wheels
Stock wheels are 8” wide and depending on trim have +47ish to +57ish offset. Let’s call it 50mm for simplicity and let’s simplify 1” to 25mm
18x10 is a wider wheel and going from ~+50 to -24 is 75mm ish more offset in the outward direction. Quick math shows that wheel sticks out 4” more than stock
Simplified: 8” wheel with 0 offset is 4” from the wms. Bring that in ~50mm and it’s 2” from hub
10” wheel with 0 offset is 5” from the wms. Bring that out 1” and you’re at 6” from hub
Why are you set on a 10” wheel? Plenty of 18x9 choices that are tried and true.Good explanation! I had not even thought about the wider wheels sticks out about 4" more inches, but the centerline of the tire sticks out about 3" more... Personally, I would love to see a 18x10" wheel for the Rams with 32mm positive offset. this would allow running a 35x12.50 without rubbing the radius arm and without sticking out too far.
I'd settle for an 18x9 with about 32mm positive offset.... Not sure why Ram and Ford both, have 18x8 wheels and 20x8 wheels, at least with GM you can get OEM 18x9 and 20x8.5... The width so you can properly mount 12.5" or 305+mm wide tiresWhy are you set on a 10” wheel? Plenty of 18x9 choices that are tried and true.
Good read.Here is a good read on tire fitment and wheel offset.
