Whats the chances these fit
Hemikc4x4
Feb 10, 2024
‘24 Ram 2500 diesel. Stock suspension
Have Moto metal 18x10 -24 wheels and 35x12.5 tires ordered. How bad do you think these will rub? And will a leveling kit keep them from rubbing?
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
There are quite a few examples of __x10 with negative offset -16 up to -44 on the custom offset gallery. Check it out. Should give you an idea of how much poke you’ll have and they list if they had to trim or not
Rockcrawlindude
Jan 1, 2021
Georgia USA
Here is a good read on tire fitment and wheel offset.
This ^
I wasn’t gonna tell him that he ordered the wrong wheels and should’ve researched before buying rather than after. I’m trying to be a nicer person.
Hemikc4x4
Feb 10, 2024
This ^
Thanks. Definitely didnt order wrong wheels. Got what i wanted. Will put whatever size lift that is needed to make work. Wouldnt be first new truck that i have used a hammer and saw on. Lol
Hemikc4x4
Feb 10, 2024
Appreciate it. Actually looked at the gallery. That is where I actually ordered my tires and wheels. But by all the pictures appears they will fit maybe with just alittle rubbing. I was kinda more curious if anyone had similar sizes and actual results.
Hemikc4x4
Feb 10, 2024
Definitely had to put a leveling kit. Just a little rubbing. Will do alittle trimming. But turned out great. (It doesnt look level due to driveway. But it is exactly 44” from ground to fender front and back)
johanh13
Aug 10, 2019
is that a 35x12.5 on the wheels you mentioned? 18x10 with -24mm offset ? also, would be curious to see a view that shows just how much they stick out (from the front to the side, where you can see the front and back tire) thanks
Rockcrawlindude
Jan 1, 2021
Georgia USA
Those would stick out a lot. About 4” more than stock wheels
Stock wheels are 8” wide and depending on trim have +47ish to +57ish offset. Let’s call it 50mm for simplicity and let’s simplify 1” to 25mm
18x10 is a wider wheel and going from ~+50 to -24 is 75mm ish more offset in the outward direction. Quick math shows that wheel sticks out 4” more than stock
Simplified: 8” wheel with 0 offset is 4” from the wms. Bring that in ~50mm and it’s 2” from hub
10” wheel with 0 offset is 5” from the wms. Bring that out 1” and you’re at 6” from hub
Hemikc4x4
Feb 10, 2024
I will get you a picture. They do stick out alot. But its what i was looking for. They still stick past the fender flares. But i personally hate the look of trucks with fender flares and the tires are way inside of them. I prefer them outside.
johanh13
Aug 10, 2019
Good explanation! I had not even thought about the wider wheels sticks out about 4" more inches, but the centerline of the tire sticks out about 3" more... Personally, I would love to see a 18x10" wheel for the Rams with 32mm positive offset. this would allow running a 35x12.50 without rubbing the radius arm and without sticking out too far.
Rockcrawlindude
Jan 1, 2021
Georgia USA
Why are you set on a 10” wheel? Plenty of 18x9 choices that are tried and true.
johanh13
Aug 10, 2019
I'd settle for an 18x9 with about 32mm positive offset.... Not sure why Ram and Ford both, have 18x8 wheels and 20x8 wheels, at least with GM you can get OEM 18x9 and 20x8.5... The width so you can properly mount 12.5" or 305+mm wide tires
GR1MxREAPER
May 4, 2024
He already has the wheels and they are literally installed on his truck in an above pic… no point to telling him to get something else people lol.. 18x10 or 18x12 wheels fit the same. The trimming is the exact same.. drill a hole and pull the liner backwards with a zip tie (nice and quick) trim the pinch weld about 1/2” from bottom up about 6-8” and boom Plenty of room .. don’t let others talk you out of what you want. 75% of people run 0 to -44 offset 9/10/12” wheels and They all rub unless you do the trim lol.
I prefer my paint not getting chipped to hell from rocks lol, i drive a lot of gravel roads so stick out is an issue for me. Hell even 1/2 the highway princess trucks here with the tires way out have a ton of paint chips… everyone has their preference i suppose
jsalbre
Oct 29, 2019
ID
I’m with you on that one. I’m running stock Duratracs with wide RokBlokz mud flaps and still have rock chips and my rear fender flares look like they’ve been shotgunned.
