Yup. I ordered in June. A month ago they said to expect them in March. Almost there!!
I have these at home right now! With Fox shocks. I’m at work, overseas, currently. Will be installing when I get home June 3. It showed up right before I left, dang it! It’s going on a 2500 Hemi MegaCabAnyone do a Thuren 3" + 1" rear soft ride on a 2500 hemi?
What all are you selling?selling all my Thuren stuff,sold the truck.
son of a gun....well buddy, I look forward to your safe travels home and the install. This is what I want and believe I can stuff 37's with minimal hacking. Did you go remote res. on the shocks or just the regular ones? I hate to copy you, but great minds and all that jazz.I have these at home right now! With Fox shocks. I’m at work, overseas, currently. Will be installing when I get home June 3. It showed up right before I left, dang it! It’s going on a 2500 Hemi MegaCab
I went with non-resi. My 37” Ridge Grapplers just showed before I left for work too. Hopefully won’t have much trimming. I am eventually getting wheels but for now plan on running them on the stock wheels.son of a gun....well buddy, I look forward to your safe travels home and the install. This is what I want and believe I can stuff 37's with minimal hacking. Did you go remote res. on the shocks or just the regular ones? I hate to copy you, but great minds and all that jazz.
Thanks for posting this! I was just re-reading this entire thread today trying to figure out what I want to do. I'm actually leaning towards the 1" traxada spacer you currently have. I'm not really interested at the moment in running anything bigger than 35s. Plus I dont have a problem with the way my truck currently rides and want to keep the payload and towing capability.For those that still follow this thread
After at least a year, maybe two, and many many miles I have decided I want to continue to run factory springs but I do want 37”s.
Currently running a 1” front traxada spacer, no front swaybar, FOX 2.0 IFP shocks, no rear lift and stock rear swaybar. (FYI - i might be able to fit 37”s as is)
I have a BDS 2” front spacer sitting in the box in the garage because it would’ve been too much lift for a “level”
I just ordered a 1” traxada rear spacer. My goal is to run a 2”/1” spacer lift and install longer bump stops in the front (included in the BDS kit).
After Installing the front 1” lift on the truck, the front axle was shifted 1/16”-1/4” (it’s hard to measure any more accurately) to the driver side. After I install the 2” lift I will do my at-home alignment as usual and then i will determine if I want to order a track bar at that time or continue to run the factory track bar.
FYI the front trackbar is a “maintenance item” and the factory trackbar just gets replaced as a whole unit when the bushings wear out. So, eventually, it will be replaced regardless. Both carli and thuren trackbars are serviceable.
basically I am going up 1” all around for $100 upgrade price and around $2k tires +/- a couple hundred bucks depending on what I actually order.
FYI My front shocks are already good for 2” lift and my rears are good for 0-1.5” lift
1” front, for me, was perfect for 35sThanks for posting this! I was just re-reading this entire thread today trying to figure out what I want to do. I'm actually leaning towards the 1" traxada spacer you currently have. I'm not really interested at the moment in running anything bigger than 35s. Plus I dont have a problem with the way my truck currently rides and want to keep the payload and towing capability.
I’m not home but here is the application chart. I can verify the actual part numbers laterCan you post up the part numbers for the Fox 2.0 front shocks you currently run? I know you posted them in the past but I cant find the post at the moment.
I have the 1" spacer waiting to go on, waiting to get shocks and find motivation to get out and put it on .
I tow lots and no front sway bar, no issues even with emergency maneuvers. I had to do one with my 5th wheel on the truck no way i wanted to hit a moose with my camper on lolBest mod I ever did was remove the front sway bar. But I never towed anything.
