Hey all. My 2021 Ram 2500 Cummins sticker says 65 PSI for all 4 tires. Prior tow vehicles had a specific PSI for towing. Not finding that anywhere in my manual. I assume Ram recoes the same PSI for towing then? Any thoughts appreciated.
The tire only tells you the max inflation, which is generally not needed.
Each manufacturer has a Load/Inflation guide...if you are still running the Firestone Transforce, then here is a link to the guide
Firestone TBR Load And Inflation Tables
Tire manufacture charts show inflation required for different load weights....Not good advice.
OP asked about towing. When towing, you want the tires inflated to the PSI with which their load rating is based on.
Unloaded, or daily driving? Sure, deflate them a little.
Not good advice.
How is the Manufacturer Load and Inflation Tables 'not good advice'?
Seems that you didn't bother to take a look at the link...
A: 600lb of tongue weight is not enough to make the truck handle differently or make the tires notice any difference.Thanks. I will go and weigh the truck to see where each axle lands at and determine PSI based on this table.
The main reason I’m asking is that even with a full bed and towing, I find the truck bounces a lot. Trailer is light at 600# of TW but still... just wondering if I should try towing at 60 all around to see what it does.
And yes, these are the Transforce tires.
Correct, I go by the recommended cold PSI on the on the door jam sticker period.Fair enough.
My comment was more to the guy (most folks id imagine) that runs 1 set psi unloaded (maybe 50 psi or so) and another psi loaded (max mfgr rating).
I dont think folks carry around a manufacturer load psi guide and adjust their pressures depending on what's in the bed of the truck.
Given my tongue weight is that light, do you think reducing pressure to 60 would make the truck less bouncy? Would it be a problem to do that? Just trying to find ways to make it more stable while towing. I got weight distribution everything is level so that’s not the problem. It’s the truck did bounces every time there is a little road imperfection.A: 600lb of tongue weight is not enough to make the truck handle differently or make the tires notice any difference.
B: transforce are ass
Well, good question. I guess out of habit more than anything else. Was towing that TT with an SUV before and needed WD. Got the Ram to tow an incoming TT that will be heavier and longer. The hitch is not distributing a lot of weight but I’m, perhaps mistakenly, thinking that I need it to prevent sway.Why do you have weight distribution on that? Probably making the bouncing worse in my opinion.
If you have a phone you can get inflation specs .Correct, I go by the recommended cold PSI on the on the door jam sticker period.
I carry a load inflation table for both my truck and trailer. I have weighed the truck front and back axles as she sits with wife, dogs and hitch. I will get a weight for the truck with the fiver hooked on the first time I tow it in the fall. I use those weights to determine the cold inflation pressures. Right now I am running 60 in the front and 40 in the dualls. I run 65 psi in my 16 inch load range E trailer tires. Yup, I am OCD when it comes to tires.Fair enough.
