Tow chain or tow strap?
RV_Goose
Aug 14, 2020
My last chain got left on a trailer holding down a tractor. Pretty sure it was a 3/8 chain. Looking at tow chains to have on hand as I have needed them 6 times in the past 2 months, And I did not have any. I see 3/8 welded chain (AgriSupply), 20ft, that comes with the hooks. They also have the 3 inch tow strap in 20 feet lengths. In the mud bog in Eastern NC right now, I had to get pulled out 3 times, and pulled out 3 others.
In snatching out some trucks (an easy pull didn't work) The chains work. I am not sure the tow strap would have held together.
3/8 is pretty heavy duty and will probably do all I desire. Lighter chain I am not sure would hold for snatching. I've done it for tree stumps and vehicles.
What do yall use?
jadmt
Aug 29, 2020
Age
65
Missoula
When chain snaps it's a very, very bad situation. There are snatch straps and tow straps, the former is dynamic and the latter is static. I carry both for different situations.
X100. two completely different uses. of snatching get a bubba rope. it is the stretch and recoil that gets someone unstuck if buried.
Dont use chains i have seen enough dented tailgates and busted out rear windows with mild tugs, straps are rated much higher than chains.... or a bubba rope like mentioned works great
I carry both and use the appropriate tool for the job.
Hate to wrap my nice pull straps around a fallen tree blocking the road. Hate to try to pull stuck vehicle with a heavy chain. Sometimes you need both to protect your gear and the object you're tugging on.
RV_Goose
Aug 14, 2020
Is there a huge difference with Bubba rope brand and the others?
LateToTheParty
Didn't want to come
Jul 29, 2020
Roxborough, CO
On paper I would assume all kinetic ropes would be the same. I have only ever used the true Bubba brand as that is what I have, but if I was buying again I'd look at specs before the name.
jadmt
Aug 29, 2020
Age
65
Missoula
I don't know, but Bubba is quality and paying more for quality up front usually saves money in the long run.
GBB
Jan 4, 2021
Nylon 3 stand..1 1/4” rope..used it for years and pulled many a vehicles out of ditches. over 40,000# breaking strength
Bozo
Self-banned
Feb 24, 2020
Definitely a recovery strap for me. Tow ropes and chains break on the jerk. Really need the stretch and recoil action for those tough stuck times.
RV_Goose
Aug 14, 2020
I'm looking into the bubba rope as well as other brands. I also watched videos that state the straps and ropes are only good for a certain number of pulls. But as I am not a pro doing it all the time, I hope to not hit that limit.
A strap is the best option for you, your not pulling people out of swamps so a kinetic rope is a waste... i have had the same 35ft strap good for 80k for about 10 years its been great pulled many vehicles out
RV_Goose
Aug 14, 2020
Well, most of the eastern half of North Carolina is either paved or mud. ;) :)
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
Definitely a Tow strap, snatch strap, recovery rope. Call it what you like
Chains are NOT the right tool for the job.
my recovery bags each have multiple snatch blocks, multiple d rings, tree straps, tow straps, winch line extension ropes, etc. but they include zero chains.
Chains have their spot holding **** down on the trailer thats about it
Also tow straps with steel hooks ... big no-no
soft loops on either end.
to make a closed system use d-rings
I wish i had a picture of my old 03 chevy work truck hood from my younger days with a hooked strap it went through the leading edge of the hood and i was hardly pulling...
