Im reading through this thread, lots of observations of poor brake feel. What are things people can do to improve it? 1) change brake fluid, it should be changed every 2 years as it absorbs lots of water which lowers its boiling point and results in spongy brakes. bmw, Porsche etc all recommend at least every 2 years, or after every track event to keep boiling temps high, once the fluid boils your brake peddle is going to the floor.. 2) change pads, what a lot of folks here don’t like is the soft initial bite the stock pads have. Switch to a more aggressive pad, with more initial bite, and you’ll have much stronger braking response with less pedal travel. Sorry more dust, and noise are often the trade for good brake response. 3) move to stainless steel braided lines, the cheap rubber lines in these trucks expand with braking pressure causing you to have to push the pedal further. 4) that’s the end of the cheap options.. I cheated my brake fluid and it had a big difference. My previous car / tow vehicle was a bmw x5m which had manhole cover sized brakes, and was in a different league in breaking.
