bigontheblue
- Joined
- May 8, 2023
Huh? +18 or more? For a stock width of... ? 7.5? I was under the impression that stock at ~+44 and 7.5 wide would rub. That's more than 18.... do you mean less than 18? Help me, I'm derp!?37s should fit with any wheel that has +18 or more offset with either very little or no rub at all.
FWIW there are better shock options at stock length then OEM replacements, id go that route if you are going to be replacing shocks either way.
Thuren recommends +18-25 for stock width. I'm considering rims that are -16 @ 9.5 wide. If you consider vertical placement only then +44 - 25 = 19 for the change in width. Similarly 18-25( or 18) =-7 (or zero offset) for a width change only with recommended offset on 7.5" wide wheels. The wheels I'm considering are only 9mm proud of recommended... check my math and logic plz but it seams I should be good to go.
