Free is better than a 140$ hope and prayer because if you need that it means the vent is plugged anyway and needs to be changed/ cleanedInstalled my ATS Doomsday device today
My dealer said there was no fix right now, so until they have the parts, I figured this could be cheap insurance. I tow a lot, and didn't want any mishaps before they could fix it.Free is better than a 140$ hope and prayer because if you need that it means the vent is plugged anyway and needs to be changed/ cleaned
The parts are availible your dealer is full of itMy dealer said there was no fix right now, so until they have the parts, I figured this could be cheap insurance. I tow a lot, and didn't want any mishaps before they could fix it.
Ok, good to know. My dealer was just sold a month ago, and the service department is a ****e show right now. May they to schedule an appointment at the dealer in S Georgia then.The parts are availible your dealer is full of it
Nevermind, thought about it and it's not a good idea.Speaking of the vent, what's with the L-angle vent? why not simply run a hose to the firewall or such, reinstall the vent cap and call it a day? Sure would keep debris away from it.
They could forsure lengthen the vent and would be ideal for water crossing but for the avg driver the vent is plenty sufficient where it is and the angle just keeps it away from the top of the case where it can collect dirt and mudSpeaking of the vent, what's with the L-angle vent? why not simply run a hose to the firewall or such, reinstall the vent cap and call it a day? Sure would keep debris away from it.
If it's like any of the others, it's a one-way vent. Made by Goretex?They could forsure lengthen the vent and would be ideal for water crossing but for the avg driver the vent is plenty sufficient where it is and the angle just keeps it away from the top of the case where it can collect dirt and mud
It could be but it just looks like a normal 5$ Dorman cheapy from Flan’s picture on the previous page. I know the front axle vent on these trucks is the one way gore-tex but i have not even looked at the rest to see if they were the same i assumed they were not but never confirmedIf it's like any of the others, it's a one-way vent. Made by Goretex?
Correct. Make it a point to keep your old dipstick. I wouldn’t drive my worst beater into a quick lube joint, no worries for me!I was told that with the new fix you can no longer check your dipstick level. It would have to be done at the dealer and it takes 45 minutes to check. Don’t expect Jiffy Lube to be able to do it.
That's nuts! If that's the case, then I will just keep my AFE device and dipstick, thank you very muchI was told that with the new fix you can no longer check your dipstick level. It would have to be done at the dealer and it takes 45 minutes to check. Don’t expect Jiffy Lube to be able to do it.
Just keep your old dipstick….. and it would only take a dealer 45mins to check everyone else can do it in the same 30 seconds as before if you keep your OEM dip stick in the garage or truckThat's nuts! If that's the case, then I will just keep my AFE device and dipstick, thank you very much
Got a hundred bux 90% of the 16 were on rental from enterprise commercial to hotshot truckers tipping the scales at 25999 running cross country with two drivers.What were the operating conditions for the 16 fire balls? In other words, what time did the 68RFE get to? Were they towing/hauling a heavy load?
I wonder how likely it is mine will burst into flames if I'm just driving around empty?
Im sure he was also trying to maintain 80mph in the mountains too! Those guys usually have no clue how to do anything safely.Got a hundred bux 90% of the 16 were on rental from enterprise commercial to hotshot truckers tipping the scales at 25999 running cross country with two drivers.
Saw a dude in Kentucky last year in a 3500 with the SO/68RFE, said it was a rental… had 3 cars on a gooseneck trailer and was griping that “this thing doesn’t feel like it has 1000 ft. Lbs. of torque”. I told him it didn’t since it was an SO, then he spent 10 mins bitching about the trans overheating in the mountains.
I just had the recall ZA3 (transmission tube) done 1/18/2023 on my 2022 Ram 2500. Dealer told me with the replacement tube, you CAN NOT check the transmission fluid yourself? WTF ? Service man said the tube is shorter and does not have a dipstick.
If you take a moment and read through this thread you will see there are many options for you to be able to check your trans fluid. You will need to buy a dipstick since you didn't ask for your old one back. The tube has not been changed....only the length of the replacement dipstick.
They DO NOT change the dipstick tube they only change the dipstick to one that locks in position. They keep the OEM dipstick so that there is no chance someone removes the new dipstick and just keeps the OEM stick in the transmission. You can use the OEM dipstick to check the fluid after the recall thats what the dealer will be using as they are instructed to keep atleast one of the old ones for checking the fluidOk. Let’s say they don’t remove the tube, but add a non-removable cap, or a cap that adds quarter inch to the tube, how would you get an accurate reading? Can someone on this forum confirm that we can still use the dipstick if the recall is done?
I’ve got to believe there will be a problem with that because my dealer says they have to keep the OEM dipstick once the recall is completed. You don’t get it back. I would think that if the OEM dipstick was still usable to read the fluid level, they wouldn’t be keeping it.
