Very nice. No drilling?Installed the Proclip 19+ mount with phone cradle. Ran the wire into the dash and down to the port in the center console. Solid mount and now full time Apple CarPlay.
Correct, just clips on and has a very small strip of two sided tape on the vent side. It’s solid, no movement at all. Only thing I wish was different is the angle was more towards the driver.Very nice. No drilling?
You can always go with ProClips tray mount that uses the factory screw holes in the dash try. That way you don’t have to worry about removing that nasty double sided tape and you can turn it anyway you’d like. Once you mount it, position it and tighten everything up it won’t budge. The best mount that I have ever found and used.Correct, just clips on and has a very small strip of two sided tape on the vent side. It’s solid, no movement at all. Only thing I wish was different is the angle was more towards the driver.
Not sure why you would need a phone mount? Once the phone it plugged in, I don't look at it again and can access what I need through AA.
It’s not just a means to make Audio calls for me, I use it to FaceTime my GF and my daughter sometimes and having a solid mount makes the most sense to me.Not sure why you would need a phone mount? Once the phone it plugged in, I don't look at it again and can access what I need through AA.
I’ll be using that mount as well, to use as a dock for my Garmin InReach Explorer+. It was most useful traveling through zones with no service. The cradle in my Tacoma was ideal, I’m happy someone makes solid products for the Ram as well.You can always go with ProClips tray mount that uses the factory screw holes in the dash try. That way you don’t have to worry about removing that nasty double sided tape and you can turn it anyway you’d like. Once you mount it, position it and tighten everything up it won’t budge. The best mount that I have ever found and used.
RAM Extra-Strength Center Dash Mount with Pedestal Arm
This ProClip dash mount is custom-made for your RAM truck. (see compatibility tab for full list of years and models) The mount attaches in the storage tray above the center screen and includes a built in 5 inch adjustable pedestal. In addition to mounting regular holders for a phone or GPS, this...www.proclipusa.com
Hemi trucks get the 8 speed with the rotary shifter.Why do you have a rotary gear shifter? Half ton?
I got one of those CarPlay things from China. Works perfect. However it does like an install and thought for sec it was gonna download a virus or something...I was sure to give them a positive rating when the auto-email for rating was requested LOLthe only thing is now missing is
a bluetooth carplay ...
That's a great mount, probably the best. However, they don't have one for a truck with the 12" screen.You can always go with ProClips tray mount that uses the factory screw holes in the dash try. That way you don’t have to worry about removing that nasty double sided tape and you can turn it anyway you’d like. Once you mount it, position it and tighten everything up it won’t budge. The best mount that I have ever found and used.
you’re one of those people that makes video calls while driving? Stay home if you want to make a video conference.It’s not just a means to make Audio calls for me, I use it to FaceTime my GF and my daughter sometimes and having a solid mount makes the most sense to me.
Hopefully, you are stopping off hiway in a safe place when you are Facetiming.It’s not just a means to make Audio calls for me, I use it to FaceTime my GF and my daughter sometimes and having a solid mount makes the most sense to me.
Proclip has a pedestal mount now for 12" screen trucks, but I prefer the RAM mount system (also had lots of it.)
RAM Extra-Strength Center Dash Mount with Pedestal Arm (Large Screen Models)
This ProClip Center Dash Mount is a custom made vehicle specific mount. The ProClip Center Mount is a very sturdy mounting bracket that clips tightly into the seams of the dashboard. No drilling holes or dismantling of the dashboard is required, simply clip on in seconds.Device Holder NOT...www.proclipusa.com
X2 on the ram brand mounts. I have one in my crawler, phone didn’t budge when I rolled three times. Cheaper mounts have snapped right off on just large bumpsRam mount bases. I used one that had to be cut down a bit and holes drilled to match the dash cubby. Longer screws and Bob's yer uncle.
Popular Components - B Size
RAM® Mounts is the industry leader in rugged motorcycle and car phone mounts, rugged tablet mounts for trucks, forklift mounts, and more. Find the perfect device mount for your car, truck, motorcycle, plane, forklift, snowmobile & many more.www.rammount.com
Top level page for B size mounts and parts
