Power outlet - truck bed
Woodall83
Oct 3, 2020
Can anyone with a 2021 model confirm or deny that there is an available 115V power outlet in the truck bed, on the drivers side? This would be without Ram boxes and without the 5th wheel prep. I found the image in the '21 brochure.
diode_ee
Dec 23, 2020
It's funny, I was wondering the same thing. I found the switch for receptacle in the manual, but haven't been able to determine what option is required to get this on a non Ram box configuration.
I'm hoping that the trailer prep package includes the receptacle.
Sent from my Pixel 2 XL using Tapatalk
noizy21
Dec 21, 2020
Yes, I just received my 2021 RAM 3500 with the trailer tow prep and the 115 outlet was in the bed of the truck. Looks like as long as the package you ordered has the 115 installed on the interior, it will be installed in the bed also if you have the trailer prep package.
noizy21
Dec 21, 2020
It was actually a surprise for me. I had started seeing videos on YouTube and then when I looked at my build sheet, it was listed. I didn't specifically order it. "Exterior 115V AC Outlet" is what is listed on my build sheet.
@Jimmy07
I'd like to retrofit on my 2020. I have a better(bigger) converter I would use, but using the factory switch and hard parts would be my preference.
Any way you could dig up the parts for us?
Woodall83
Oct 3, 2020
What is the trailer tow prep? Is that the fifth wheel prep?
Woodall83
Oct 3, 2020
Gotcha. They make it out like it is available without that group but can't confirm.
bfs673
Jan 8, 2021
NE Salt Belt
My '21 came with it as well. Was surprised.
There's a switch in the cab to turn it on/off.
Epsilon Plus
Sep 11, 2020
My interior one couldn't even run my Shark household vaccum. Can't remember if truck was running or not. It definitely couldn't run my Harbor Freight air compressor with truck running. Start up amps probably too high.
Im reduced to thinking it only has balls enough for a laptop brick or something.
That's all they're really intended for. 400W is pretty low.
I have a spare 1KW converter sitting doing nothing that I want to add to the bed.
Jimmy07
Re-coding from an easy-chair
Apr 5, 2020
@Jimmy07
I’ll check it out. I’m sure it’s the same outlet part and switch part numbers used on the ram boxes. Unfortunately, I doubt the switch could be used on an aftermarket inverter because the bcm and Lin bus is involved with the factory inverter module.
diode_ee
Dec 23, 2020
I don't see that on my build sheet and hope it comes on the limited trim which has the towing prep package. I didn't even see that as an option when using the online builder.
I think I saw it in one of the standard or package screens.
Pronto
Nov 23, 2018
Texas
It's listed on my build sheet as Exterior 115V AC Outlet.
diode_ee
Dec 23, 2020
Yup, I looked back over the window sticker and notes the same line item. Thanks! Good to know and I'm surprised it's not more evident on the ram site.
el_barto
May 25, 2020
Firsti was like “Neat, I want that”... but then I realized I’ve never used the one on the center console.
What would one you use this for, even if it was wired into a 1000W Inverter? All my power tools are battery powered now.
