b307a1
Well, that raises the question as to why isn't there the wheel hop issue with the longer wheelbase?I love being wrong it means I learned something new. Thanks man
That would be the Snow Chief PackageSomeone here may correct me but I think another perk of the Off-Road package is the auxiliary switches? As someone who puts aftermarket lights and accessories on every vehicle I own this was a huge plus for me.
I think it's worth the initial investment. The only thing I don't like is the badge on the bed. Kinda dumb but it doesn't hurt anything.
I’m just glad I didn’t bet money on it.Well, that raises the question as to why isn't there the wheel hop issue with the longer wheelbase?
You don't look like an ass for doing something we all do and you are right that we all learned something from it.I’m just glad I didn’t bet money on it.
I already look like an ass, I am fine with that as long as we’re all learning.
But, at least I didn’t lose any money
Yah, I noticed that when I checked it out on the RAM builder site. I'd have to say the Snow Chief package is probably worth more to me than the OFF-ROAD package. The fact that my truck has both is just a bonus.That would be the Snow Chief Package
I noticed after I replied That You found the info. The Snow chief package is the best. It also allows you to keep the black grille/bumpers on a Tradesman...where rhe offroad package makes you get chrome...just for infoYah, I noticed that when I checked it out on the RAM builder site. I'd have to say the Snow Chief package is probably worth more to me than the OFF-ROAD package. The fact that my truck has both is just a bonus.
Ah damn, i know its not axle wrap but its a similar feeling.... i guess ill have to buy the shock because in reverse on wet pavement thats inclined it will do it mainly when the plow is onYea, the shock compresses and extends so the distance changes
anti wrap is not needed in a 4 link there is zero axle wrap
the shock is angled upward pushing slightly downward on the pumpkin providing resistance against wheel hop.
LOL...no kidding!SEE NOW. This is so much more interesting than can I fit 35s or what will my mileage be
Let us know your engine and cab/bed config and if you do or don’t have it.So now I'm curious and I'll check under my truck at lunch. I'm guessing I don't have the middle shock but I have looked into trac bars and other items to reduce hop while towing. This maybe a simpler solution if available.
I remembered this same conversation from a few years ago on another forum, and someone got “a reply” from the chassis engineer-Let us know your engine and cab/bed config and if you do or don’t have it.
Interesting.I remembered this same conversation from a few years ago on another forum, and someone got “a reply” from the chassis engineer-
Well guys I just received a response from a RAM chassis engineer.
"The 5-link coil system does an incredible job of locating the axle and improving the ride. We put the Bilstein dampener in place for additional control, bringing us far beyond what competitors offer. The dampener exists on gasoline engine models (6.4 and 5.7 HEMI) but not on Cummins-powered trucks. Diesel engines have a much different torque curve and RPM range and do not currently require the component.
The five-link coil design incorporates support at all major points of force. Leaf spring suspensions struggle to combat axle wrap by using staggered shock absorbers (one mounted on the front of the axle tube and one mounted on the rear of the axle tube). The superior design of the five-link coil system functionally resists unwanted axle rotation. Leaf spring configurations also lack lateral support, forcing the leaf ends and shackles to hold against lateral loads — a task they're not particularly good at and one reason competitive leaf-sprung rear suspensions shutter on rough surfaces.
Because of the unique five-link axle control and natural rotation, U-joints in the driveshaft run smoothly and with less vibration through the suspension’s range of motion, an advantage not shared with leaf springs. Another benefit of coil springs is less unsprung mass and elimination of stick-slip friction found between the leaf springs. Additionally, links are engineered in-line with frame rails, so overall packaging is better, not to mention an overall weight reduction of about 40 pounds when compared to a leaf-spring configuration.
The 2014 Ram 2500 also will offer a segment-exclusive rear air suspension system. Two air bags replace the coil springs much like the Ram 1500. Load capacity is not sacrificed and the 2014 Ram 2500’s best-in-class ride and handling gets even better, crushing the competition with two doses of engineering innovation (five-link coil standard and air suspension option). Another benefit to the new air suspension design is the load-leveling capability, which automatically detects load on the rear suspension from a trailer or payload. The air pressure increases until the vehicle reaches normal ride height – leveling the truck and improving stability and loaded ride."
I received an additional response that added a little more detail.
G56 CTD gets the shock.
The 2WD Crew Cab short box (gas) doesn’t, nor does a 2WD Crew Cab long bed. I did not get the answer about the Mega.
Olli. End forum post quote.
It was also answered at the end of the thread that the mega cab did not get the shock.
Good call. Back on track.Well I sure unintentionally started a big long discussion here But at least I guess I got me answer. Yes....get the off road package for the shocks alone! Thanks.
Do you have a CCLB ? Interested now
Crew cab long bed with the cummins. Off-Road package & Snow Chief package. No middle shock (might get added now).Let us know your engine and cab/bed config and if you do or don’t have it.
