jadmt
Mine july 1 of 2020I wonder when they switched. Maybe the manufacturing date determined when they switched over to 87. Mine was made in July and recommends 89.
I have a 2020 with the 6.4 and the owners manual says 89 octane is recommended.my 2020 owners manual says 87 and no mention of 89. Page 471.
6.4L ENGINE
Do not use E-85 flex fuel or ethanol blends
greater than 15% in this engine.
This engine is designed to meet all emissions regulations and provide satisfactory fuel economy and performance when using high quality
unleaded gasoline having a posted octane number range of 87 as specified by the (R+M)/2 method.
While operating on gasoline with an octane number of 87, hearing a light knocking sound from the engine is not a cause for concern. However, if the engine is heard making a heavy knocking sound, see dealer immediately. Use of gasoline with an octane number lower than 87 can cause engine failure and may void or not be covered by the New Vehicle Limited Warranty.
I used to believe that too but after actually testing the fuel i have yet to find a local station that actually has 91 that tests how 91 should most endup testing at 89 octane and containing about 5% ethanol91 is ethanol free here so that's what it gets. No ethanol will touch my engines.
And we get charged the premium for this so called special blend.I used to believe that too but after actually testing the fuel i have yet to find a local station that actually has 91 that tests how 91 should most endup testing at 89 octane and containing about 5% ethanol
The power of marketingAnd we get charged the premium for this so called special blend.
I mentioned it in your other post, but I run 85 all the time. Granted, I'm in Colorado so the altitude allegedly has some impact on how that performs, but I've had no issues following this approach through multiple Hemi's.has anybody try add regular 85 and just add octane boost additive?
Just about all gas comes from the same depo's these days. The only difference is the additive package that gets mixed in when it is pumped into the truck.I’ve been running 87 in mine since I got it in November of 2019. Haven’t noticed any issues around town or pulling a 7k lb camper into the mountains of NH & VT. So weird that they have conflicting info online & in print manuals...
Somewhat on the same topic - how bad is Sam’s Club gas? I know top tier brands are the best stuff, but is Sam’s as bad as the El Cheapo stations I used to see in GA?
Costco is part of the TopTier branded family.I’ve been running 87 in mine since I got it in November of 2019. Haven’t noticed any issues around town or pulling a 7k lb camper into the mountains of NH & VT. So weird that they have conflicting info online & in print manuals...
