No 12v power on 7 way Trailer Plug Wiring Connector. Need Help
Still a work in progress as I haven't had time to revisit, but for the trailer fuse, here' s the detail.
These ARE M-case fuses, but I prefer the Bussman style "FMM"
F3030 Amp PinkMCASE(FMM)/Trailer Tow Receptacle / Trailer Tow (Separate E-Brake)/Trailer Tow (BUX)
GenericBussman
A - Micro 2.
B - Micro 3.
C - Maxi.
D - Mini.
E - M Case.FMM
F - J Case.
G - J Case Low Profile.FMX
H - Slotted M Case.
Slvrhemi85
Feb 4, 2021
Well IT was the fuse located at #30. Previous owner might of blew or im actually wondering how it did blow. Went to wally world for the fuse....no luck. Then oriely. Got pink 30 that I THOUGHT was the correct size.....turns out it wasn't. This one is slightly bigger. WHY DIDNT I BRING IT WITH ME TO THE STORE.....I wish I knew lol. Well was bummed when I found out wrong size. I got 1 hour until dealership closes. BUT BUT BUT then I LOOK thoroughly at fuse box to find out there is an EXTRA fuse located top left corner of fuse box. In business now. Wanted to let all know the update as well as the fact there are extra fuses in the fusebox....maybe save someone the trouble.
slimchance
Jul 14, 2019
near Lancaster, Pa
2019 Ram 2500 BH ... have a problem with my trailer lights .. checked the bumper plug with a test light (both 4 pin and 7 pin test the same) ... i have tail lights, left turn signal BUT no right turn signal ... signals all work on the trk ... i have trailer tech package, but have NOT tested the in bed plug .. any ideas??
The fuse for trailer right signal is blown im sure
do you know which fuse that is AND what size/style it is???
Look in the lid of your fuse box it will tell you what fuse is what…. And im not sure what they list em as they are some sort of mini blade fuse but low profile
slimchance
Jul 14, 2019
near Lancaster, Pa
you we right, opened the fuse box, used the chart in this thread, found the Macro 20a fuse and found it blown... did not have this size fuse (Macro) neither did TSC but Advance Auto had all sizes and good stock ... plugged in the new fuse and walla right turn signal ... you and this thread saved me LOTS of time ... as for the fuse box lid, whose idea of a joke is that, black letters on black background ... i am 72 yrs old not 12 yrs old ... thanxs again @H3LZSN1P3R ... wife said your the BEST
kcustom
Mar 14, 2022
interesting tread, I am having an issue when I meter pin 4 and show same or very close voltage to what the truck is showing at front at battery. When I connect my 7 pin to my 5th wheel voltage drops. I have determined that when I connect something causes pin 4 to disconnect from the truck and voltage drops to what ever the camper battery is showing. the second I disconnect the 7 pin voltage restores to alternator voltage. Where to I start looking? appreciate any insight.
Do you have a molded plug on the trailer? If so show a pic of the pins on it. It could be the old style that causes voltage drop due to lose terminals
kcustom
Mar 14, 2022
I was thinking it could be the trailer plug, so I replaced it with a Heavy duty 8 foot. 10 ga on power and ground. what is weird is that when I don't have the truck connected I show the same voltage at pin 4 as dash alt voltage. but when I connect the 7 pin voltage drops to voltage on camper battery and it will not charge.. disconnect and voltage return to match alternator output. I have replace the 30 amp auto reset breaker in the J Box on the camper as well. I even ran an 8 gauge jumper from the breaker in the J box to the camper battery to bypass the camper wiring and the same happens. Fuse F30 is good as well under the hood. I am baffled.
Thats odd that it wont charge how long was it left to see if it was charging?
kcustom
Mar 14, 2022
I let the truck run for almost one hour.... really odd. I think I am going to see if I can find the wiring diagram from the TPIM to the 7 pin plug and see if there is a breaker in line some where. I am baffled....
Its not a TIPM in these trucks ill tag @Jimmy07 he may be able to set you on the right path
