I entertain the rear control arm loosening/bounce/tightening idea, but just not in a position to do so yet.
Also, I wonder about the aftermarket rear control arms, but get confused on their required bolt torque based on the different joints (by manufacturer). I am told the stock ones do store energy, yet I know the same feelings are present under the stock springs on my truck, so unless they were installed and tightened incorrectly (under droop or compression instead of neutral/static weight), I just overthink it as being another red herring.
If we discuss here the finer points of WHY the stock arms store energy as opposed to the style of joint that doesn't (heim). Any guidance here (
@Rockcrawlerdude ?). Anyway.... Why is this considered a necessary bushed joint instead of just a pivot and an allowance of the shock to take the hit? Is there a subsequent ride quality interaction here when they work correctly within proper parameters, but go to the dark side when incorrectly applied?
NO, I don't want to throw $ at this, but trying to learn why things are set up this way if it causes issues based on my attempts at suspension nirvana. It does seem most aftermarket arms are just for big lifts (although handle 0" if adjustable.
