Mud Flaps
Pronto
Nov 23, 2018
Texas
I picked up the RokBlokz XLs and I love them! No drill, no problems simple install. :)
Are those the original size or the XL?
Edit: Nevermind, I read right past it even though it's cited in the quote I posted. Doh! BTW, looks good!
OuachitaAdventure
Jul 3, 2019
What size front and rear did you get? Any part numbers?
Here's my invoice
1DF12 13/14:DF12L 13/14 SS NBStyle DF12 Extra Long, pre-drilled for 2013 - Current Dodge Dually and 2014-current Dodge 2500/3500 front, 12" wide, with Stainless Steel weights without bolts.
Powder Coating WeightsPowder coating a pair of weights
1DR20 10:DR20L 10 SS NBStyle DR20 Extra Long, pre-drilled for 2010 - current Dodge Dually 4WD rear, 20" wide, with Stainless Steel weights without bolts.
ShippingDiscounted Shipping
Blazchasr
Nov 16, 2020
Panama City Florida
I had the XL's on my 2018 because I had 2 1/2 inch fender flares, but on the 2019 I have the regular size and they still extend out a little bit, but if I put the oem fender flares on it will about right
jadmt
Aug 29, 2020
Age
65
Missoula
just installed some Mopar flaps $55 after discount at local dealer. easy install and perfect fit.
NC Rebel
Sep 2, 2020
I installed the Mopar OEM flaps front and rear, they seem to be heavy duty . Install was a little tricky but not terrible.
jadmt
Aug 29, 2020
Age
65
Missoula
I just installed these, what part was tricky? I thought they went on really easy.
Squatch
Mar 21, 2020
Washington
I got the idea to make my own from @1FastHemi ...
Both front and back are 14" in width... just in case I either go with a wider tire at some point or I change out the wheels as none have the same amount of offset as OEM so they will stick out a bit.
I simply reused all the existing hardware... I did drill one hole in the plastic well to support the innermost corner on all four sides, I think Duraflap comes with a clamp..
So I used this image from @MegaDave to make my template for the front:
Basic pattern cut out...
This is the reason for the weird shape on the front flaps:
Held on with some duct tape to make sure they are centered...
Gondul, would you mind sharing the specific mud flaps product you bought. I like the rubber you used, I found some stuff on Amazon, but it seems more plastic than rubber.
Gondul
Prince of Pintops
Mar 10, 2019
Totally understand... I ordered them through Northern Tool as they were the cheapest at the time, the part # is BSGD2430 (24x30 - 3/8" thick) it is a composite material.
The weights I got from Bores MFG, again,
Squatch
Mar 21, 2020
Washington
Thanks, you’re the man!
relbus
Sep 15, 2020
Chicago
Thanks to this thread I made a decision on mud flaps. Weather tech is local. Grabbed a set this morning curb side pickup and had them on later in the day. Easy install, look good. I’m happy, but I haven’t driven it at all.
