my weathertech fir perfect upfront factory steps, maybe they sent you the wrong ones?
Care to post a picture of yours installed so we know which steps they work with
Check that the step itself can be moved back slightly. I think where the step itself bolts to the hanging brackets it may be able to be adjusted.Thank you! I wonder if you could take the steps off, pull the plastic cap of the front, then shorten the tube a little so you have clearance?
It took me a while to get back to this... There is no adjustment where the step bolts down. I did take the steps off, removed the end cap, cut the step rail back 1", redrilled and reinstalled the caps. Looks great now with about 3/4" clearance from the running board end cap to the mud flap.Check that the step itself can be moved back slightly. I think where the step itself bolts to the hanging brackets it may be able to be adjusted.
What width did you end up at on the fronts? They look darn good! Have any photos looking in at how you cut them?You can make your own...
4- 24x30 Composite mudflaps shipped from Northern Tool for just over $70.
4 weights from Bores MFG for just over $50
A couple of hours with some cardboard and some beer...
That’s exactly the info I needed thank you!! I’m going with duraflaps, but want them to stick out like yours beyond the factory flare for the same reason. I think I’ll have them add an inch to outside vs both inside and out. I really prefer the 12” width, but I don’t think they’ll be able to shift the holes/cut a full inch. I know I could just make them, but time is money and it will cost me more to make them in the end both time and money. Thanks again for the great info!!
If anyone talks to megadave tell him to check his inbox I’m hoping to see some photos of his truck/flaps from further back and looking down the side of the truckJust for a follow up I put the rear DuraFlaps on. I chose the extra long stainless. They mount really solid. I like them so far.
Are those the 14” wide in the front?
Pretty sure he did the 12sAre those the 14” wide in the front?
Correct, fronts are 12" and the rears are 20".Pretty sure he did the 12s
I had a set of these on my 2018 2500 and they worked great. Ordered a set for my 2019 2500I picked up the RokBlokz XLs and I love them! No drill, no problems simple install.
