Follow Up on my
@DuraFlap Post- I installed the Item no. DF12L 13/14 on the front fenders and the DR12L 16 on the rear one day last week. Attached photos intended to illustrate one way drive to work before DuraFlaps installed, installed in driveway, same one way drive to work with DuraFlaps and then a washed truck and slow speed driving version in town.
INSTALLATION: The only way it could have been easier, is if one of you guys came over and installed them for me.
Very simple and straight forward.
Other thoughts: I don't think there is any thing that will keep the "spray" off the side of the truck carried by turbulence once you get above about 25MPH. Our road is a very good road, as far as dirt and gravel goes. In the summer and dry, it is easily driven at 50MPH other than a few corners. It is still a gravel road. The tires kick up a lot of gravel onto rocker panels, etc and the DuraFlaps have seriously cut down on the amount of gravel that hits the truck.
I'm very happy with them. These 12" wide flaps are nearly the same width as the tire treads. I'm wondering if wider flaps would provide a significant amount of additional protection from gravel dings.
Length- If you notice with truck backed up to curb, about 1.5 inch clearance from bottom of flap to curb. DuraFLap advises you should have at least 7" from bottom of flap to driving surface to keep from ripping the flaps off when pinched between the tire and an obstacle, like a curb.
