mopar Power Deployable Running Boards
Desertfox73
Aug 19, 2021
Great question - I will check in with our team. It may be something that they're still not keen on doing if it is not specifically listed as availbale/compatible even though it may have been "proven" (as much as one could ask for) above. I'll let you all know what I find out! I can say one thing for sure, is that I personally would not be mechanically inclined enough to do it - but that's stories for another day.
lol - thanks for checking on it, I appreciate it and am excited about the truck. Knowing what I have planned for it, I'll need all the help I can get to make sure I can actually get in!
AnthonyRI
5thGenRams Vendor
Jan 30, 2023
Mark Dodge CDJR
Ok the service & parts team had a pow-wow - and while they're not doubting that this CAN be done, by someone . . . it is not something that we would be able to do at dealership still given the fact that it is a little borrowing/adjusting from different items and instructions we wouldn't be able to have the same sure footing as we normally need in order to make adjustments to a brand new vehicle. Bright side is they did say the methodology looks right so shows hope!
Dave01
Aug 26, 2022
I live in central NH, am out in every storm including today. No issues with them deploying or stowing. I think the mechanism is seriously rugged, as you might hope for. Like Splzhaul mentioned above I try to wash them pretty regularly to keep sand out of the mechanism.
I meant to add some pictures but forgot until now. This shows the kind of icy buildup that happened during a storm, doesn't seem to affect their operation at all.
Dave01
Aug 26, 2022
There is typically a lot less buildup with mudflaps.
You know I've thought about mud flaps and haven't done anything yet. If there's a "these are the ones to go with" obvious answer, let me know, OEM or other.
Desertfox73
Aug 19, 2021
Lots of guys running TRX have good things to say about WeatherTech flaps. If they work well on a truck that gets hammered off road, I would imagine they’ll do well on wet roads.
I like my OEM rubber Flappy Mcflaps. There's a big flap thread here somewhere. You can spend a lot more on Duraflaps and a few others, but IMHO the OEM ones get er done.
jsalbre
Oct 29, 2019
ID
The OEM rubber flaps are easy to install and look nice. I had those on my 2020. I went with Rokblokz on the ‘23 as they’re a little wider, and actually easier to install than the OEM flaps.
Dave01
Aug 26, 2022
Thanks guys, appreciate the feedback, I'll make a choice and order a set shortly. I knew there had to be a flap thread, or maybe a bunch of them, just didn't have the gumption to read a bunch of flap pages.
Now for fender flares, I may be reading a few threads ....
Shane644
Apr 26, 2023
Looks good. One thing I failed to mention and didn’t think about- Can Bus wires should be twisted pairs to even out any interference they may pick up. It shouldn’t be an issue here (more of a “best practice”), but if you aren’t too far along, take the two Can IHS wires and twist them together.
Thanks for the heavy lifting. Followed wiring diagram and the 2019 boards work fine on my 2013
ironmike
Nov 15, 2020
Bakersfield , CA
I am looking for help in the of power steps operating properly. I have a 2020 Ram 3500 Mega Laramie HO 4X. The steps have worked properly until about a month ago, passenger side started intermittently working when it wanted to, sporadic deploys & retracts. I pressure washed for debris removal and re lubed pivot joints with PB Blaster & WD-40. Worked a little less sporadic but not for long. Also, drivers side started same symptom as well 1 week ago.
Any help, is greatly appreciated!!
thestuarts
Jun 10, 2019
If you're still under the 36,000 mi warranty or an extended warranty, I would just take it to the dealer to troubleshoot it.
Both "lubes" used are penetrating oils used to break stuck parts free and are dirt collectors if left.
Flush it as needed, then use spray white Lithium grease.
I'd be checking connectors and fuses as well.
cjthompson206
Jul 23, 2023
This has been an extremely helpful thread. The only challenge I run into is finding the following items as they are discontinued.
68361654aa power running board, right
68361655aa power running board, left
I assume there are newer options but cannot seem to find the correct P/N's. Couple questions.
1. Does anyone know what the newer part numbers are?
2. Does the PSSM, wire diagram and connectors shared earlier in this thread still apply to the new power running boards?
Much appreciated for the help!
Sent from my Pixel 6 Pro using Tapatalk
Gondul
Prince of Pintops
Mar 10, 2019
I think they are out of stock rather than discontinued as they'd normally list a new p/n
These folks claim to have them in stock...
cjthompson206
Jul 23, 2023
I tried ordering from 2 places and moparpartsgiant was one of them. Both places cancelled my order.
Gondul
Prince of Pintops
Mar 10, 2019
Sorry about the bad link then.
Vendors really need to update when items are out of stock vs showing they are available for purchase...
Jimmy07
Re-coding from an easy-chair
Apr 5, 2020
It’s been a while since they stopped selling the left and right power running boards as whole units.
Now, the only way to get them is to buy each individual part of the power running boards separately to piece together the whole units.
Dave01
Aug 26, 2022
Last winter when plowing I dented my passenger side running board on a rock I didn't see. Expensive mistake, but then again the board protected the rocker so no damage to the truck. A local autobody repair guy I use did the replacment for me, not sure where he got it but had it in within a week. I'll see if I can track him down to ask him.
cjthompson206
Jul 23, 2023
No worries, Gondul. Really appreciate the input.
