Here's a roll-up thread for posting links to any successful DIY Sales code mod and AlfaOBD settings required (or not) and common AlfaOBD settings only mods.
This is NOT a How-To or Q&A for AlfaOBD or discussion thread. Links and settings only please.
TL;DR If you're not here to contribute, you can probably skip the rest and just look down to the lists. Please don't clutter the thread with comments unless you wish to contribute. Questions will be moved to a related thread.
Common AlfaOBD questions
Q: What do I need to use AlfaOBD?
A: AlfaOBD Android or AlfaOBD Windows, a bypass cable (KAOdTECH recommended), a Windows PC or Android phone/tablet, a supported OBD Reader or cable (OBDLink MX+ or Vlinker MC+ recommended)
AlfaOBD offers a discount for a second license. Some features may be available in only the Windows version.
Q: Where do I plug in the KAOdTECH Bylass cable?
See this post: https://hdrams.com/forum/index.php?...module-location-for-programmer.440/post-26099
Q: Can I enable Global Window Down?
Q: Can I enable Auto-folding Mirrors?
A: No. Door modules in the 2019-2022 HD trucks do not support Global Up/Down or Auto Folding Mirrors.
Third party "active" modules like the Tazer-RAM may have these features but AlfaOBD is passive and can only change BCM settings, and only affects supported module(s) functions.
AlfaOBD can change only BCM settings*. Not all BCM settings shown in AlfaOBD may be supported by your truck.
ECM*/TCM, Radio modules cannot be recoded by AlfaOBD. There are some diagnostic procedures supported (ABS initialization procedure may be required for tire size change), clearing codes, etc.
* There's a few ECM options that can be changed (idle timer). Use with extreme caution.
Instructions:
Uploading System ID (BCM) Information:
Common AlfaOBD settings
Interior
DIY Sales Code mods
(Continued)
While there's already an AlfaOBD thread, it seems many mods and settings are scattered to the four winds and there's always a lot of repeat requests for the same info, partly because people don't search. Here's a post you can direct everyone to if you don't have the info handy. The most popular and lengthy mods are usually already a sticky. Particularly those that were a group effort to develop. Not everyone has, or needs to, read through an entire discovery thread just for one quick settings change.
If you contribute, I'd prefer these are links to HDRams posts if one exists. If there's one elsewhere that deserves a link, please consider creating your own post with the info and providing the link (with credit if appropriate) or if absolutely necessary, an off-site link.
For simple, one-off AlfaOBD changes, just describe it and show the setting, link optional. If it's lengthy, see above and link or create a thread. Members posting the answer to a question may get a mention (type @membername... until they show and then select it).
One of the staff will update the first post as others are added. If you add a post and don't see it show up in the summary #1 post after a few days, please REPORT your post and ask that it be added.
- HDRams AlfaOBD thread Please search that thread if you don't see it here.
- Monster sister site 5thGENRAMS AlphaOBD (sic) thread
- Monster AlfaOBD thread on ramforum
- Google Drive AlfaOBD settings doc (use at your own risk)
- Alternate Google Drive docs (credit 1500ram12 @ramforum)
Make a backup of your original BCM configuration before making any changes.
Instructions:
To upload your System ID (BCM) config use the "Tools" icon in the upper right corner. Select "Upload to Google Drive," and link your Google Drive to AlfaOBD. Select "Upload to Google Drive" and "Upload Faults and Status Log". Select "Body_Chrysler_Info".
Interior
Turn on EVIC Gear Indicator Post - ECUConfig 4-Actual Gear Display: Yes
Then turn on in EVIC screen setup
Disable Automatic up/down feature with the driver/passenger front windows post - VehConfig 3: Window Express Feature Configuration (@Jimmy07)
Disable ANC: P/T Chassis Net: ANC Active Noise Cancellation- Disabled (@Jimmy07)
ExteriorEnable Fog Lights with Highbeams - CBC Features-Front Fog Lamp Dropout Enabled: No
Disable Signature LED lighting: To turn the accent lights off- CBC Extern Light Calibr: Signature Light Present- NO @Jimmy07
Program Tire Size Google doc (from Google Drive link above)
One of the better videos I've found here (just make sure you're using the correct MY): https://www.youtube.com/watch?v=HlKk3YZ7ecI
Run the ABS INIT procedures shown in this post/image. The ABS INIT doesn't do anythign so the option is greyed out. Just do the steps: https://hdrams.com/forum/index.php?...-and-common-alfaobd-settings.3468/post-223855
Disable FOBIK Panic Button - LIN and Misc-Panic Enabled: No
Enable Forward facing camera gridlines and selection ala PowerWagon (requires 360* cameras) @jsalbre
(only confirmed to work on most 2500 trucks, no known working 3500 ) Also confirmed working on UC5
Enable LED Bed Lights - larger install thread here: led-cargo-bed-lights-wiring
Enable tow mirror axillary reverse lights (for trucks shipped to restricted states) - 2014 CBC Config I/O & Feat.- Baggage (Cargo) Lamp Output Disabled with vehicle moving = NO
DIY Sales Code mods
- Adding Trailer TPMS Thread
- Adding Hill Descent
- (Hemi 8-speed switch and settings) @RamThis2500 Panel part number: 68368375AF
- (Hemi 8-speed Manual Transfer Case switch) Panel part number 68378095AD @Jimmy07
- (Diesel 6-speed switch panel P/N: 68370837AE)
- Adding Remote Start (JSCAN can now program HD FOB's)
(Continued)
