LETS SEE THOSE 35'S ON STOCK WHEELS
LegendaryLawman
Legendary Pessimist
Oct 20, 2022
What kind of MPG drop are you guys seeing with the 285 Falkin at3? I personally wouldn’t go with the 12.5 wide tires prefer slightly larger than stock 285/65 would be a nice happy medium imo
Fuzzy D
Feb 29, 2024
35 12.50 17 on stock power wagon....the Nitto grapplers very slight rub due to the side profile...
swapped to toyo at in the same size and no rub.
now back in a diesel Rebel....dont care for the 20's but gonna run them for now20230430_093014.jpg
Can it be done without changing the payload ?
Payload is a number that can’t be changed, up or down, by mods. It can legally be changed under federal law, but that’s a different story.
With the proper reverse level there will be no negative side effects to load handling, especially if airbags are included in the reverse level.
whitexc
Jan 26, 2021
WNY
My truck is bagged already. Is it a matter of a spring swap or would the Bilsteins need to be replaced as well? I would do it soon.
Sent from me
Sent from me
Depends on how low you want to go. Shorter shocks, a different trac-bar, and anti-swaybar links could all be needed if you go low enough.
