LED light in tailgate handle
g00fy
Mar 3, 2020
g00fy
Mar 3, 2020
Ok so Benny at allmoparparts said he can't find a part number for the LED light so he's thinking it's part of the tailgate harness which has it's own number exclusive to the 2022MY. The part number is 68521314AA which unfortunately is currently unavailable for order and unpriced... I'll post back here when I get any updates on it.
Thegame
Jan 5, 2022
I have these two part numbers for my Laramie 2020 black
Thegame
Jan 5, 2022
I received the tailgate handle today but it does not include the light does anyone have the part number for that light
g00fy
Mar 3, 2020
I just received the 2022 tailgate jumper harness and it does not include the LED light itself... So the search continues.
Thegame
Jan 5, 2022
wow and i just ordered the harness it will be something different from 2020
copcarguy
Jun 13, 2021
Can’t wait to see what’s needed / required to get this installed… hoping it’s plug and play similar to the fog lights.
Jimmy07
Re-coding from an easy-chair
Apr 5, 2020
It definitely won’t be plug n play. First thing that has to be done is cut the main connector off the new tailgate harness, and use the old 4-way tailgate connector with new terminals for it. Then, the lamp circuit will have to be added to the chassis side 4-way connector and either tapped into the bed lights, or run to the BCM where it’s dedicated circuit originates (assuming the pre-2022 BCM has the capability).
This is the new 2022 tailgate harness to chassis harness connector:
Compared to the 2019-2021 tailgate to chassis harness connector:
copcarguy
Jun 13, 2021
i just ordered the light the missing piece
Can’t wait to see a pic of the actual light, based upon what Jimmy posted above I’m wondering if it’s possible to just run dedicated wires to the light itself and tap them into one of the LED bed lights.
Thegame
Jan 5, 2022
install the harness and it seems to work perfectly almost everything is the same except for the connector for the new auxiliary light
Jimmy07
Apr 5, 2020
Does the new tailgate jumper harness go all the way to the chassis harness connector, like the arrow is pointing to in the pic, or does it only go to the tailgate/body transition plate?
tehhippy
Feb 22, 2022
My light has been finicky since the day I got the truck - sometimes goes into a strobe-like mode and I suspect it's not as bright as it should be either... Anyways, dealer is replacing under warranty but the light part itself is apparently backordered - no ETA on when they'll get it. Will report back here when they get one and can provide the part # then as well (if that helps anyone).
