Possibly using a relay and a blocking diode, you could do both - Bed lights or reverse lights.
Did you get the part already and it fit up no issues?I hope this isn't the 3rd wasted DIY I've installed.
Also what were the first 2?
Make sure you are in 4LO. I got the opportunity to off road in my 2500 with off-road pkg earlier this month. Hill doesn’t have to be steep, but shifting into 4 lo before hitting the hill descent was required.The other was the Hill Descent. I either need to find a significantly steeper hill or it just doesn't work. The way it acts, I'm leaning towards it doesn't work on a 3500.
Part is ordered. I need a new tailgate due a mishap between wife-truck-boat trailer so I ordered it along with that.
Kind of waiting to see if Jimmy will be able to get Alex to put the code in for AlfaOBD. Then again, I'll get it painted when the tailgate gets painted so I'm stuck with it regardless. I'll wire it up if I can't make it factory.
I added TTPMS so technically it works, but I couldn't sync up my sensors and decided I wanted temperature which isn't offered.
No parts purchased, but I also never got Forward Facing Off-Road Camera working, also believed to be due to having a D2 3500.
Where'd you order from? And did you get any updates on your order yet? When I check the status on mine it's just blank, doesn't say processing or shipped...
Get it yet?Moparpartsgiant - they had by far the best shipping rate for the tailgate I ordered.
Ordered 9-27, received order update 9-28 that the parts had been ordered from the parts center, ETA 10-6.
Get it yet?
Oh that sucks! I’ve been watching this post to see what needs to be ordered.So fun fact, the led strip is Apparently a separate part
