I installed it.
Part no.
6YK08TX7AA (black with bighorn on it)
My tradesman has a black dashboard and this matches perfect. Only 1 issue the bezel underneath is smaller on tradesman than bighorn so I have a gap. I'm searching for that part number now.
First remove the radio there are 2) t20 torch on top under the rubber mat than it pulls out from the clips. Watch a video on that to see how hard you gotta pull- Its in there.
Next remove the bezel ( long trim piece above lower glove box and below cubby. It's held in with clips. Cargill because one clip by the radio trim is backwards. Go easy and watch inside as you go. ( I didn't and that clip shot into the dash idk where)
See the one tab missing his clip. That's the one that's backwards. Just want you to watch that guy. if you go to yank the whole thing off that whole tab might break.
Next remove glovebox.
Under the glovebox is a fabric cover with 3 plastic push pins. Remove those pins ( buy some btw).
Under the cover you will see 2) screw with 7mm heads. Remove those.
Go to the top where you just removed bezel there are 6 screws staggered and 2 other on the left by radio area. Remove all 8.
Now is when you can remove glove box. With the two lower screws removed it is only held in with clips pry it looks with a plastic tool or give a tug.
With the glove box removed look up under the dash there are 2 screws holding in the cubby. Gonna need a 12" extension to reach up in there.
Once screws are removed the cubby is ready to be removed. It doesn't have clips.
Install the upper glove box. The black tabs on it's backside sit below the tabs that held the two screws.
This is the tab. Notice my cubby tab is attached and. There is no cubby. So that how I found those.
When you go to put the screws back in slide a piece of paper in the socket so the screw doesn't fall out of the socket.
Once those are back in it's time to put it all back together.
Took me about 45 minutes to figure it out and install it. Not a bad job at all.
I will update the trim bezel part no when I confirm it's correct.
