I bought my 2019 Ram 2500 Ram Laramie Off-road Black Edition on Sept 21, I noticed mine doing the same thing. When you passed a semi or other large vehicle it got worse. On the Gen 5 1500 forum they talk about this issue and there is a TSB out for this issue on theirs but not ours yet. The TSB states that the issue is that the hoods cross brace is not attached to the hood except for at the four corners. The cross brace is stamped steel and the hood is aluminum, obviously two metals you can’t weld together. The TSB states the fix is to install body bonding adhesive, in I think it was 13 locations, between the cross bracing and the hood. It says not to close the hood or drive the vehicle for 24 hours while the adhesive cures. I checked several older trucks, including my 2006 that I traded in for my new truck, and the cross brace was attached to the hood at all four corners and at the center location. So I took the 1500 TSB with me to my dealership and told them mine was doing the same thing. I gave them a copy of the TSB and they reached out to FCA and after a couple of days FCA told them to go ahead with the fix on my truck. It’s a cheap fix, a tube of body bonding adhesive, new clips that hold the hood insulation in and a couple of man hours to do the work. Once the work was completed I took my truck out on the interstate and went 70 mph for a bit and passed several semis to test the fix. The fix worked beautifully, my hood no longer shakes or lifts looking like it is ready to fly up. Just as an FYI... I have a great reporte with my dealership and they told me they went back and fourth with FCA several times before they threw in the towel and told them to go ahead and fix it. At one point they told the dealer that they couldn’t even find their own TSB but my dealership pushed back and FCA caved.
On another note... I did some online research and found that this is / was not only a Ram issue, Ford Honda and a couple other manufacturers were having the same issue with their vehicles with large aluminum hoods.
