fuchsroehre
Not sure if you meant it that way, but:Your payload is your truck's weight subtracted from 10,000 lbs. It's a legal issue to be classified as a 3/4 ton pickup. The only reason a competitor 's equivalent 2500 can have a higher payload is due to having a lower curb weight. The bigger the cab and the more options you have all add to the weight of the truck. If you want a 2500 with a higher payload, stick to a regular cab Tradesman. Modern trucks are heavy, mainly because they are larger and offer more luxury options than the typical pickup from 10 years ago. It's simply the way consumers have pushed the market.
Sent from my SM-G981U using Tapatalk
What I have noticed is that the GVWR of Ford's and GM's 3/4 ton trucks is >11,000lbs. They also weigh about 8k lbs but that gives them 3k lbs payload ratings.
To drisso88:
There must be toy haulers which are not 5th wheels. They probably also have less drag because they do not build that high.
And if it needs to be a 5th wheel, aren't there some with roughly 2k lbs pin weight? It would "feel" better if you could be within limits, at least on paper.
Did you ever talk to a 5th wheel sales person? Do they care about the pin weight detail?
