I just tried to make some changes and I can't get any changes to do anything different save for DRL dropout. Including the turning them on or off via the radio (option is enabled and present).
The 4 sig lights and lower strip are the only DRL that will light up.
But I only tried with AlfaOBD Android.
DRL None, Dedicated, etc. = no change.
DRL lamp set to fog, dedicated, none, etc. = no change.
Maybe I'm not letting things cycle, but I can flip the DRL dropout No/YES while the truck is in Run or running without any cycles. and it changes
Alright, I see why it’s not working on an HD truck (non-export). The dedicated DRL circuits from the BCM are not used to drive the signature lighting like they are on the 5th gens and exports. You would need to switch two wires around on the bcm connectors to make it happen. This is a big PITA if you have a factory amp because it has to be removed to gain access, but I’ll show what wires they are in case you, or anyone else wants to do it. You have to de-pin the wire in C1/A pin 5, and re-pin it in C1/A pin 22. Then, de-pin the wire in C1/A pin 7, and re-pin it in C4/D pin 15.
AlfaOBD settings will be as follows:
ECUConfig 3: DRL Customer Setting Option Present- Yes
CBC Features: DRL Configuration- Optional DRL
CBC Features: DRL Lamp Location- Dedicated
CBC Features: DRL Dropout Enabled- Yes
CBC Config I/O: Right Dedicated DRL Lamp/Right Signature LED Present/Right Front Turn Signal #2/Headlamp Leveling Output Present- YES
CBC Config I/O: Left Dedicated DRL Lamps/ Left Front Turn Signal #2/Left Signature LED Present- YES
CBC Config I/O Usage: Front Park/Signature Lamp Left Pin A7- NO
2014 CBC Config I/O & Feat.: Bed Lighting Present Pin A5- NO (you might have to switch over to DT MY2020 BCM to get this setting)
CBC Extern. Light Calibration: Signature Light Present- NO
CBC Extern. Light Calibration: Left Side (and right side) DRL Voltage Target- ADJUST HOW YOU WANT FOR BRIGHTNESS
CustSetMenu 1: Daytime Running Lights CSM Present- YES
The above method will get rid of low beams for DRLs, make the signature lighting the only lamps on as DRLs, will make the signature lights adjustable for brightness through alfaOBD, will make the signature light “drop out” on the side that the turn signal is being used, and will be able to be toggled on/off with the DRL radio setting.
