gimmie11s
- Joined
- Mar 30, 2021
Ok…. Got everything done today! Still waiting on the back ordered front shocks. Temporarily added a 3/4 spacer on top of the stock shock to get it to work until the others show up. Obviously would be better with a 2” adapter for the bottom of the stock shock, but I plan only to pound pavement with little articulation until the front Fox 2.0’s arrive. Did a Thuren 1.75” front and 1” block in the rear. Added Thuren sway bar, adjustable track bar and Fox stabilizer. Block, air bag spacer and u-bolts are Traxda products, which CJC Off-Road sells, but I found them elsewhere on sale. Just FYI, air bag spacer is more like 1.25” but works great. You do have to spin air bags around to make it work, but it’s 2 top and 2 bottom bolts. You got to get truck leaf stack pretty high above the axel to get the block and bolts on the the leaf pack. Just use lots of safety cribbing. I made my own adjustable rod to tinker with the air bag height. The balls are 8mm if anyone is wondering. I got the ends off eBay for around 10-12 bucks and some 6mm stainless all-thread off Amazon for like 7-8 bucks. Put heat shrink on the threads to black it all out. Works good. I have bags almost empty. I read somewhere someone got a code if running them too empty. I too got a “stability” code. Added a turn out and re-attached the bars, went on a drive and the code went away. Bags are still pretty low, but not empty, but still messing with it, and very happy so far. Can’t wait to wear out the stock tread so I can put some new shoes on it now. Let me know if anyone has questions. I did all the work. Friend has a lift, made job quicker and way easier. Curious if anyone else has seen this stability code or not. If it doesn’t come back I won’t worry about it, if it does may try one more turn on the air bag rod. Otherwise, off to the dealer to check the system.
Nice job on those adjustable rods...
