thestuarts
- Joined
- Jun 10, 2019
Has anyone found heat-resistant LED lights that can be installed in the engine compartment? I will tie the power to one of my AUX upfitter switches.
I like it! FCA engineering minions be like scratching their collective noggins about customers wondering, "where did the under hood light go?" I mean, who would wanna look under the hood when it's dark?I found an under-hood LED kit from KC Hilites that looks like it will work well. Has anyone tried this product? [I am not sponsored or affiliated with KC in any way.]
I installed the KC under hood lights. I like them a lot. I took the pictures around 11 pm.
View attachment 4570View attachment 4569View attachment 4571
Curious, did you mount a switch in the engine bay or use upfitter switches (or maybe a magnetic switch to automatically turn on)?
Stuart,
In the video the guy never put the hood insulator back on. You have yours on your hood. Did you cut out holes in the insulator or did you mount through or to the insulator?
Those KC's look sick dude, nice work.
I'm going to experiment with an alternative solution, when I get around to it. The fewer Aux switches I can tie up, on little things, the better. Baja has a very bright waterproof dome switch. The convenience is obviously in the power sourcing. Run your hot and ground and done. Click on, click off.
$75. ROFL.
Yep, very pricey. Much time isn't spent tinkering on a diesel in the dark.
Thanks for the inspiration @thestuarts. I added my underhood lights today. Pretty much same setup as you except I opted to not drill any extra holes and used the two existing indentations in the hood insulation cover.
Brutal,
If you are asking about the pins holding the hood liner to the hood a replacement part number is Ford N804379S.
When you google that part number there are several substitutions, all the same. They are :
25/64" (4.5mm), Stem: 28mm, Head: 22mm.
That's a good question. I'm also interested in the answer as I'm thinking about the same lights and don't relish drilling mounting holes in the hood.I'm not looking for the stock pins, I'm asking about what I expect would be a longer pin used to mount the LED lights.
Just curious what specifically was holding those LED lights to the hood. I can always pull one and go to NAPA and find something...
