Grid Heater Relay Recall
Combra6589
Jul 12, 2021
Yup. Dealer won’t release my 22 limited until it’s repaired
Bigred6.7
Jan 27, 2020
Just picked up my new ‘22 yesterday. How is the recall already complete if the part is in development? Will try to look at this week in daylight.
diesel_driver_3500
Apr 3, 2021
Got my notice yesterday for my 2021. I called my service department and he verified the repair. However, he then called the parts manager to check on parts, and was told the parts would not be available until February 2022.
My grid heater relay is now disconnected from the battery, and will stay that way until parts are available.
diesel_driver_3500
Apr 3, 2021
Not if you disconnect it from the battery-
This is what I did. Disconnect the wire attached to the battery terminal, where the arrow is pointing to:
https://hdrams.com/forum/index.php?attachments/24035/
I covered the loose end of the wire with the finger off a rubber glove and taped it up. I then zip tied the end to the fender strut to keep it from touching anything. Jimmy07 says disconnecting at the terminal will not throw a code. This has to be better than parking the truck outside and hoping it doesn't spontaneously combust.
rhg84
Jun 8, 2021
That sucks I picked mine up yesterday but they were calling me during my flight to tell me not to go down. Was "fixed" when i landed so who knows, nobody knew what the fix was and someone was suppose to ask the mechanic that fixed it to let me know but i haven't heard back. If it catches fire i have a nice lawsuit since it was sold after the stop sale order.
Myfast70
May 27, 2021
Will they disconnect the relay diesel_driver_3500 has done and allow you to take it that way? No chance of a fire with it disconnected and won't throw a code according to Jimmy07. Not sure how cold of a climate you live in but so long as it doesn't freeze you should be ok
Anything above 10*F you will be ok from my exp i usually skip the preheat cycle but any colder than that it will struggle to start
cycling4life
Aug 26, 2021
CA
Got the appointment to fix the recall. It is still a month out. Anyone know what the fix is?
Firebird
Sep 24, 2020
I haven’t received anything yet on my 2021
Combra6589
Jul 12, 2021
Live in Massachusetts. Dealer refuses to touch it until a engineer from stellantis calls them. No eta when that will happen. Escalated a case with ram today . I asked them to unplug it multiple times since my truck came with block heater kit
dslbrnr
Nov 27, 2020
SO Utah
Add me to the list.
Dealer won't be able to get to it until 12/29.
dslbrnr
Nov 27, 2020
SO Utah
No, I'm in possession of my 2021. I just called to make an appointment to have it replaced.
Firebird
Sep 24, 2020
Just checked my app, completely forgot about it
