My grid heater relay is now disconnected from the battery, and will stay that way until parts are available.
This is what I did. Disconnect the wire attached to the battery terminal, where the arrow is pointing to:Not if you disconnect it from the battery-
Yup. Dealer won’t release my 22 limited until it’s repaired
Anything above 10*F you will be ok from my exp i usually skip the preheat cycle but any colder than that it will struggle to startWill they disconnect the relay diesel_driver_3500 has done and allow you to take it that way? No chance of a fire with it disconnected and won't throw a code according to Jimmy07. Not sure how cold of a climate you live in but so long as it doesn't freeze you should be ok
Got the appointment to fix the recall. It is still a month out. Anyone know what the fix is?
Live in Massachusetts. Dealer refuses to touch it until a engineer from stellantis calls them. No eta when that will happen. Escalated a case with ram today . I asked them to unplug it multiple times since my truck came with block heater kitWill they disconnect the relay diesel_driver_3500 has done and allow you to take it that way? No chance of a fire with it disconnected and won't throw a code according to Jimmy07. Not sure how cold of a climate you live in but so long as it doesn't freeze you should be ok
Are they holding your truck hostage too or am I the only one in the country with a stop sale 22Add me to the list.
Dealer won't be able to get to it until 12/29.
