The Outdoorsman
- Joined
- Sep 15, 2020
Can you post a link for the “exhaust squeak” you speak of? I haven’t heard of it.this exhaust sqeak that mine doesnt really have ( yet )....
Link Brosef, link!Squeak/squeal thread in the 6.4L powertrain sub-forum.
Link Brosef, link!
I’m in the sticks on a not so smart phone. Can you just give a brother a link dammit to hell!
I just finished installing some Diode Dynamics, and ran a fuse tap from the clearance lamps to control the fogs with a relay so that I didn't need a switch in the cab. Haven't made up my mind about how I'm going to control them yet so I let the relay do the work for now.I am considering wiring the fogs to activate off of the low beams. I would like to tap off of the low beam wire to activate a relay that would power the fogs. This would allow me to avoid running any wires into the cab at all..
My only problem is that I can not locate a relay or fuse under the hood that powers the lights. And I can’t tap off of the wire powering the bulb itself because it supplies a pwm signal which I cannot use to trigger a relay...
can anyone think of a fuse or relay that could be tapped for this purpose? Specifically a circuit that only powers simultaneously with the low beams?
The part number you want, that doesn’t contain the connectors for the sensors, is 68377333AD. Problem is, it will be useless to you if you don’t have the 16-way connector present on your truck to plug it into. I haven’t heard of anybody yet that came factory without fogs or sensors having that connector present. You would basically have to cut the 16-way connector off, and extend the two fog lamp driver wires to the BCM.Does anyone have a part number for a factory LED fog light jumper harness for a 2019 Bighorn 2500? I have ordered two now and both arrived as incorrect. Maybe if you have the factory lights already installed at the factory you might have a tag on the harness that has the part number? I need the one without the front bumper sensors.
When I run this part number it looks to be a jumper that includes the wiring for the sensors. I think I might be better off doing just as you sort of suggest and that is to modify the harness I have now, and extend it all the way up to C1:1 and C4:13 at the BCM. Thanks.The part number you want, that doesn’t contain the connectors for the sensors, is 68377333AD. Problem is, it will be useless to you if you don’t have the 16-way connector present on your truck to plug it into. I haven’t heard of anybody yet that came factory without fogs or sensors having that connector present. You would basically have to cut the 16-way connector off, and extend the two fog lamp driver wires to the BCM.
That part number is definitely the one without sensors. You can’t go by the generic drawings, you have to go by the sales codes attached to the part number.When I run this part number it looks to be a jumper that includes the wiring for the sensors. I think I might be better off doing just as you sort of suggest and that is to modify the harness I have now, and extend it all the way up to C1:1 and C4:13 at the BCM. Thanks.
Anyone know the part number for the led fog lamp bezels without parking sensors as seen in the picture?I don't know if it helps or not, but I just looked at my '19 Tradesman with the factory LED fog lights (Safety Group). The driver's side LED fog has a white/yellow wire and a black wire. The passenger side LED has a white/orange wire and a black wire. Each light only has 2 wires connected. Based on the nature of the wiring now, I'm sure the LED's are wired separately from the factory such that the vehicle "sees" each LED fog light separately.
I have completed my fog light installation and while I deviated from going OEM I wanted to share my results here.
Parts used:
My goal was to avoid penetrating the firewall and installing a switch in the truck.
Bussmann BP/HHTR-RP ATR Micro II Fuse Tap
H11 socket pigtails
14ga primary wire
Wire loom
Ring terminals
Diode Dynamics SST Pros is white
All of the oem brackets, trim pieces, nuts and bolts summarized in an earlier post.
I used a fuse tap on fuse position F79 which is the circuit that powers roof clearance lights for trucks equipped. My truck is not equipped with clearance lights so I used the circuit to power my fogs, alternatively the circuit could be used to trigger a relay actuating an alternate circuit to power fogs. There was an existing hole in the fuse panel box that I was able to feed the power wire through, no modification to the box was necessary. From the fuse tap I created a harness with H11 style ends in case I decide to go with oem fogs In the future. The wire harness was grounded down by the fog location with a ring terminal to the untranslated metal bracketing of the bumper.
Wired in this way I have noticed the following:
If the parking lights are on the Fogs are on.
If the headlights are switched to the on position the fogs are on.
If the high beams are actuated the fogs stay on.
When unlocking the truck the headlights come on but the fogs do not.
When headlights are set to “auto” in low light the headlights come on in DRL mode and the fogs do not illuminate. In the darkness of night the headlights and the fogs come on.
I find it quite acceptable for now.
The led fog light bezels without sensors like on the tradesman with safety/towing upgrades. Anyone know the part number?I don't know if it helps or not, but I just looked at my '19 Tradesman with the factory LED fog lights (Safety Group). The driver's side LED fog has a white/yellow wire and a black wire. The passenger side LED has a white/orange wire and a black wire. Each light only has 2 wires connected. Based on the nature of the wiring now, I'm sure the LED's are wired separately from the factory such that the vehicle "sees" each LED fog light separately.
